Author Topic: Fidanza flywheel  (Read 512 times)
Fidanza flywheel
« on: Friday,November 23, 2018, 12:01:52 PM »
I just received a fidanza flywheel to put in my tc special.
The have not removed my existing flywheel yet because I would like to have all my parts together before tackling changingthe flywheel.
The first problem I found is that the steel clutch disc surface is only 8” in diameter while the clutch disc is 8.5”.
I measured the ring gear and the od is about 11.875” and has 139 teeth.  Does anyone know the size of the ring gear?
Has anyone else fitted a fidanza flywheel on a tc.  Please don’t respond if you fitted one on a Renault engine.  There are other threads that mixthe two and it is totally confusing.
Thanks
Re: Fidanza flywheel
« Reply #1 on: Friday,November 23, 2018, 02:51:46 PM »
« Reply #2 on: Friday,November 23, 2018, 03:18:16 PM »
Well, a Europa is not mentioned.  So I can’t tell.
« Reply #3 on: Friday,November 23, 2018, 03:40:40 PM »
It does mention the Europa, somy bad.
