Author Topic: Twin Cam inlet camshaft  (Read 1286 times)
Offline Sherman Kaplan
« on: Friday,November 16, 2018, 05:35:28 PM »
Is there a setscrew to seal the end of the inlet camshaft on the Twin Cam?  I have a setscrew for the exhaust camshaft, but nothing for the inlet.   The setscrew for the exhaust camshaft does not fit in the inlet camshaft.  Is the inlet camshaft sealed by the bolt for the alternator pulley?   The parts manual only list one setscrew and shows it going into the exhaust camshaft.  The parts manual does not show anything for the inlet camshaft that I can see.
I was planning on using Permatex thread sealer on the exhaust set screw and the alternator pulley bolt?
Thanks,
Sherman
Re: Twin Cam inlet camshaft
« Reply #1 on: Friday,November 16, 2018, 06:18:11 PM »
Oil does not come out of the inlet camshaft with the pulley and bolt removed.
« Reply #2 on: Friday,November 16, 2018, 06:36:33 PM »
Thanks, so there is no setscrew, only the pulley bolt.    Do you think Permatex thread seal is a good choice for the exhaust camshaft set screw and the alternator pulley bolt?
Thanks,
Sherman
« Reply #3 on: Friday,November 16, 2018, 06:40:08 PM »
Interesting! I don't have a TC but a BDA built by Dave Bean. He modified the inlet cam to accept an alternator pulley and oil WILL come out if the central bolt holding the pulley on. Obviously, this isn't meant to relate to a TC but I find it a little ironic that my inlet cam will leak oil without the center bolt but the TC won't!
« Reply #4 on: Saturday,November 17, 2018, 05:50:39 AM »
Is the cam centre drilled with small holes to each cam to oil the tappet where the cam meets the cam follower bucket on the head?
« Reply #5 on: Sunday,November 18, 2018, 12:53:43 PM »
Yes,the cam is center drilled with holes for each cam
Sherman
