Author Topic: My 72 Europa SS  (Read 47726 times)
Offline Sofa King
Re: My 72 Europa SS
« Reply #345 on: Sunday,September 22, 2019, 05:55:07 PM »
Sandyman, I think I could make the type 62 hood work. I like that it has Lotus DNA.
Certified, you are probably right. I will probably need a combination of both.
Since I have a spare hood, I can experiment with vents without disturbing my already painted hood.
Re: My 72 Europa SS
« Reply #346 on: Monday,September 23, 2019, 03:36:36 AM »
  Picture this bonnet inset. Keeping body lines too.
Offline gideon
Re: My 72 Europa SS
« Reply #347 on: Monday,September 23, 2019, 06:50:55 AM »
Banks list a ducted bonnet in their online catalogue at 271.40 gbp.  I think it is probably what Nick74R used for his build.  There's a good pic of the bonnet in this post
http://www.lotuseuropa.org/LotusForum/index.php?topic=2365.msg24476#msg24476
The other advantage of this arrangement, aside from increased airflow over the radiator and cooler brakes, is that it provides some downforce at the front with little drag penalty.
Offline Sofa King
Re: My 72 Europa SS
« Reply #348 on: Monday,September 23, 2019, 05:50:30 PM »
I like the look of the Banks hood. I think that I can duplicate the look using my spare. I would be hesitant to buy the Banks hood due to the structure of my frame.
I have also looked at the Elise and Evora vents. Both might work!
« Last Edit: Monday,September 23, 2019, 06:56:30 PM by Sofa King »
Re: My 72 Europa SS
« Reply #349 on: Monday,September 23, 2019, 06:49:30 PM »
You need to remember that racing aero dynamics are much different from street aero dynamics. In racing your always moving at a rate of speed that creates pressure and air flow. Street driving not so much. Be careful on designing ducting systems that don’t do anything unless your at speed. Electric fans are important solutions for a street car.
Offline Sofa King
Re: My 72 Europa SS
« Reply #350 on: Monday,September 23, 2019, 07:02:35 PM »
The engine runs very cool, so the problem is just getting rid of the heat generated by the radiator. I think that the Banks style vent would take advantage of the fan that I already have. I plan to run it without the hood for a drive on a warm day, to make sure that opening up the hood solves my problem. Then I’ll worry about building a vent that duplicates any success that removing the hood generates.
Offline Sofa King
Re: My 72 Europa SS
« Reply #351 on: Thursday,September 26, 2019, 12:14:10 PM »
Finally had a chance to put the car on a scale. It weighed in at 2075 lbs. it’s about 200 more than what I estimated / hoped.
Re: My 72 Europa SS
« Reply #352 on: Thursday,September 26, 2019, 02:07:48 PM »
That's still A LOT lighter than any current car!
Re: My 72 Europa SS
« Reply #353 on: Thursday,September 26, 2019, 04:24:44 PM »
Front to rear ratio?
Offline Sofa King
Re: My 72 Europa SS
« Reply #354 on: Thursday,September 26, 2019, 05:22:04 PM »
I just put it on a scale at a local mulch and stone place. I probably could have weighed just the front or back wheels, but I didn’t have any to wear out my welcome.
Offline Sofa King
Re: My 72 Europa SS
« Reply #355 on: Thursday,September 26, 2019, 05:28:17 PM »
I’ve seen estimates that GKN 47D weighed in at about 2000 lbs, so I didn’t do too bad.
Offline Rosco5000
Re: My 72 Europa SS
« Reply #356 on: Friday,September 27, 2019, 06:30:52 AM »
Was the weight with you in it?  How much fuel do you figure you had on board?  Most weights that are posted are dry weights I believe.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Offline Sofa King
Re: My 72 Europa SS
« Reply #357 on: Friday,September 27, 2019, 01:16:56 PM »
That is definitely with fluids. Probably about 5 or 6 gallons of gas. I don’t believe that it included me, but I was wondering the same thing after the fact. I pulled onto the scale and then got out to look at the readout. I assume that it was showing the weight as it sat and not the weight as I pulled on.
Offline Sofa King
Re: My 72 Europa SS
« Reply #358 on: Sunday,October 06, 2019, 11:36:48 AM »
Made it to Cars and Coffee this morning at Corsa Performance. Great people great cars! I had a blast.
Re: My 72 Europa SS
« Reply #359 on: Sunday,October 06, 2019, 11:47:19 AM »
I'll bet you turned quite a few heads - straddling between the sports car and hot rod worlds!  :beerchug:
