Author Topic: LOTUS letters for rear deck  (Read 2733 times)
Offline 1970EuropaGuy
    • Lotus Europa Restoration
« on: Thursday,October 25, 2018, 10:02:07 AM »
My S2 came with a set of LOTUS letters that were left off on a previous repaint. Does anyone by chance have a template or measurements for the location?
Thanks all.
Re: LOTUS letters for rear deck
« Reply #1 on: Thursday,October 25, 2018, 12:19:15 PM »
 I have a 1970 S2?. My mount holes for the rear lid are all at 1 3/4 down from forward lip.
The T is centered directly above the lock assembly.
The L top mount hole is 3 5/8 from edge
The o top mount hole is 11 3/8 from edge.
The T should be at 19 inches and confirm centerline.
The U is 26 5/8
The S is 34 inches with 3 3/4 remaining to other edge.
The bottom mount hole are not direct below top except for the T.
Dave Kaz
« Reply #2 on: Thursday,October 25, 2018, 12:21:53 PM »
Thanks Dave,
Something to work on in the gloomy weather in the PNW. :beerchug:
« Reply #3 on: Thursday,October 25, 2018, 12:44:15 PM »
 Europaguy , your welcome .
« Reply #4 on: Thursday,October 25, 2018, 04:44:19 PM »
Added the lettering, looks fantastic. A few small chips in the paint but that will be easy to touch up. Thanks for the spacing help.
« Reply #5 on: Thursday,October 25, 2018, 05:34:47 PM »
Looks great.
Misplaced my emblems or they walked off . I’ll need to buy all of them .
« Reply #6 on: Thursday,October 25, 2018, 06:04:08 PM »
It's amazing how things disappear. My chain saw has done a walkabout.
« Reply #7 on: Thursday,October 25, 2018, 06:50:04 PM »
Europaguy, what do you have to hold the letters on? When I built my car, the only thing that was available was plastic "keepers." They work but don't hold the letters as tightly as the original keepers. More recently, r.d. enterprises has started selling metal keepers that are similar to the original keepers. I wonder if they work as well as the originals. I have some keepers similar to the original ones but they don't grab the studs on the letters at all so maybe they come in different sizes?
« Reply #8 on: Thursday,October 25, 2018, 07:03:56 PM »
BDA,
I haven't attached them yet, probably tomorrow. On the 1967 MGB GT that I'm almost finished restoring the letters were just held on with caulking and never fell off. That's certainly not original however. I'm heading to Home Depot to see what might work, otherwise caulking will do for now.
« Last Edit: Thursday,October 25, 2018, 07:58:10 PM by 1970EuropaGuy »
« Reply #9 on: Friday,October 26, 2018, 08:53:10 AM »
Industrial fastener supply shops should carry these retainers, sometimes called 'speed nuts' or 'flat speed nuts' though one must be careful as I've seen numerous different products called speed nuts. They are available in different sizes.
« Reply #10 on: Friday,October 26, 2018, 09:14:05 AM »
If you were south of the border, and you felt important you would change the L for a P.
« Reply #11 on: Friday,October 26, 2018, 02:20:32 PM »
Thanks, Bainford. I know about speed nuts but it didn't occur to me to use them. I'll give them a try.
Offline cwtech
« Reply #12 on: Saturday,October 27, 2018, 06:54:18 AM »
Also Tinnerman nuts, Palnuts, or pushnuts, can be used to secure un-threaded studs.
