Author Topic: 5th Gear Detent Ball Spring & Ball missing  (Read 1192 times)
Offline dave3b
« on: Saturday,October 13, 2018, 07:02:23 AM »
When i went to remove the rear cover on my 365 gearbox ,I discovered the 5th gear Detent Ball and spring were missing. Has this been omitted because the External Reverse Detent Ball performs the same function when 5th is engaged? Or do I have a problem.  I've driven the car and 5th gear engages ok.
Re: 5th Gear Detent Ball Spring & Ball missing
« Reply #1 on: Saturday,October 13, 2018, 08:04:19 AM »
I think Banks has the ball and springs.
Offline dave3b
Re: 5th Gear Detent Plunger Spring
« Reply #2 on: Saturday,October 13, 2018, 11:09:05 AM »
 Its not a  ball but a plunger. See the pdf image from the Manual. This what is missing.
Offline Lotuswins
« Reply #3 on: Saturday,October 13, 2018, 05:09:26 PM »
Yes Dave, they were omitted as the external ball and spring served the same function and also provided resistance for reverse.  If you have an aftermarket lockout, the renault plunger and spring is a better solution (if you can find a set).
Jerry Rude
4005R
Offline dave3b
« Reply #4 on: Sunday,October 14, 2018, 12:21:16 PM »
Thanks Jerry!
