Author Topic: Window Motors  (Read 997 times)
Offline 1973JPS
Window Motors
« on: Saturday,October 06, 2018, 02:29:48 AM »
Hi Guys .... Maybe a really simple one but how do I correctly test my window motors on the bench....I have stripped out the doors and its been about 35 years since these have worked....can I just connect the terminals to a battery or is there relays etc that need it be in place?
Thanks in advance
Richard
Re: Window Motors
« Reply #1 on: Saturday,October 06, 2018, 03:03:16 AM »
Just connect the case to negative, and then positive to one of the two spade terminals. One is up, and the other is down.
I would use a 10 amp fused supply.
All of mine have worked after many years of no use.
Offline 1973JPS
Re: Window Motors
« Reply #2 on: Saturday,October 06, 2018, 10:34:37 AM »
Thank you 4129R for the reply.... Just tested both of them and they are working perfectly, although the passenger side is a lot slower.
Regards
Richard
Re: Window Motors
« Reply #3 on: Saturday,October 06, 2018, 10:42:06 AM »
Use the motor a few times, and it should speed up.
