This conversion, I think, had been discussed a while ago. The chassis mods to make it fit are a bit suspect, the front of the new engine cradle cuts the flange of the chassis nearly, if not all the way back, to the vertical web. If you were to weld the cradle in, it should work ok, but why not just cut the chassis off at the Y and build a complete new back structure?
The other thing was, I think, discussed was the very short upper link on the suspension. It looks like there will be quite a lot of camber change throughout suspension movement.
The same seller lists the seat/firewall reinforcement.
