Author Topic: Eclat upright(Vertical Link) same as Europa?  (Read 742 times)
Offline Lyngeled
« on: Monday,September 24, 2018, 03:19:46 AM »
Hi
It looks like the Eclats upright or Vertical Link is the same as Europa. But I have not found something that confirmed it. Anyone knows that?
Regards
Lars
Re: Eclat upright(Vertical Link) same as Europa?
« Reply #1 on: Monday,September 24, 2018, 07:58:24 AM »
The part number is an Elan part number:
36C6006 and 36C6005 (early)
XO36C6006Z and XO36C6005Z  (late)
Same part, just updated part numbers
The (early) Eclat and Espirt used the following part numbers:
A036C6044Z and A036C6043Z
So, no, they look to be different.  Probably the same geometry though.  Just different sized spindles, etc.
Offline RoddyMac
« Reply #2 on: Monday,September 24, 2018, 08:24:33 AM »
The difference in the part numbers that John provided are indeed the spindle size.  The 43Z and 44Z uprights are used on Elans with knock-on rims and Plus 2's, so have the larger bearings and stub axles.
I can't recall if you can swap out the stub axles, but I can check on the weekend when I'm in the garage as I have a set of K/O Elan uprights and a number of the smaller stub axles.
Though I did use a set of Plus 2 vertical links on the Eleven I built with special hubs from Mike Brotherwood.  The hubs were meant to use the small stub axle, but they also worked with GT6 bearing kits to fit the larger axle.
