Author Topic: Electric Windows  (Read 1355 times)
Offline 1973JPS
Electric Windows
« on: Monday,September 24, 2018, 03:03:14 AM »
Hi Guys I've started to restore our 1973 Special so expect a lot of questions over the next few years.... ;D
I've just removed the doors and want to strip them down for painting but how do I get the windows down??
Thanks in advance
Richard
« Last Edit: Monday,September 24, 2018, 04:23:11 AM by 1973JPS »
Re: Electric Windows
« Reply #1 on: Monday,September 24, 2018, 05:02:17 AM »
What are you trying to do? Do you want to remove the frames for painting, do you need to renew the runners and brush seals. If you have the doors off already then you should be able to just unbolt the motor and remove it (I've only done it with the motor in the up position so am not certain you can get the motor out, but worth a try). that will allow the glass to drop. Then drill out the rivets that holed the flame in. The manual shows you how, plus there has been previous posts on doing this
Offline Gary t
« Reply #2 on: Monday,September 24, 2018, 07:19:30 AM »
When I took my doors apart I could not get the motors out with the winder in the up position. I used a 6amp battery charger and bumped it to the middle position and out it came.
Gary Toffelmire
54/1173
« Reply #3 on: Monday,September 24, 2018, 07:25:21 AM »
I have taken 14 motors out in the up position.
Just undo the 4 x 7/16" bolts, pull the wiring out of the bottom of the motor, and carefully pull the wheel out of the metal channel, and then feed the lever through the large hole.
It is a bit fiddly, but it definitely comes out in the up position.
Offline 1973JPS
« Reply #4 on: Monday,September 24, 2018, 10:49:53 AM »
I searched for a good hour for this subject but couldn't find it.....I'm wanting to remove everything for painting and fixing broken crossbars and just a general tidy up
Offline 1973JPS
« Reply #5 on: Monday,September 24, 2018, 10:51:36 AM »
Thanks Gary .... how did you bump them to middle? and why 6 volts
Offline Gary t
« Reply #6 on: Monday,September 24, 2018, 12:06:56 PM »
6 amps not 6 volts
Gary Toffelmire
54/1173
« Reply #7 on: Tuesday,September 25, 2018, 05:30:49 AM »
Have you a workshop manual find them here
http://www.lotus-europa.com/manuals/
Offline 1973JPS
« Reply #8 on: Friday,September 28, 2018, 10:58:45 PM »
Thank You Buzzer this is really useful...I do have the factory manual but some topics just aren't fully covered.....
