Those aluminum gas tanks are sure nice!
i agree.
this tank was repaired in two spots. the fail is at one of those stamped "ribs", and i have removed the patch.
it doesn't seem to be a rust issue- more of a small break in the rib, and i will try another patch.
"the lotus" budget would prefer a less expensive solution, if possible, and it could be fun.....?
also- the float has fluid in it. i don't think enough to sink it, and the sender seems functional, so mabe it's a wire issue.
any clever float replacement ideas? somehow this thing must leak, but i see no signs of a hole in it.
havnfun110619
managed to repair(so far) the fuel tank, pulled the aftermarket fuel gauge that had failed-reinstalled original, started test drives to work, replaced ignition points, condenser, and coil(something in there seemed to overheat), and took a nice long drive in the country.
quite pleased with myself.
colorin'111119
been doin' a little "bodywork". none of this is at the quality i've seen on this forum, but …….
kinda treating "the lotus" like my boat. used bilgecoat on the undersides of the boot lid and engine cover.
still have ideas on making the engine cover open backwards- experimenting with some hinges- with encouraging results.
