Author Topic: Window frame sealant, what to use?  (Read 1823 times)
« on: Saturday,August 18, 2018, 03:44:34 PM »
It looks like something hard was used to fill the gap between the aluminum frame and door frame. What sealant works best when putting the frame back in? Does anyone have a pic showing the meeting of the two? My cars was in pretty bad condition when I got it so I don't know what it should look like.
Offline SwiftDB4
Re: Window frame sealant, what to use?
« Reply #1 on: Saturday,August 18, 2018, 05:47:44 PM »
That should be a rubber gasket between the two.
Offline Gary t
« Reply #2 on: Saturday,August 18, 2018, 08:30:01 PM »
No relationship but there is a guy in Ontario Canada that has good knowledge and a selection of seals for Europas
www.macgregorukcarparts.com
Gary
Gary Toffelmire
54/1173
Offline yellow16TS
« Reply #3 on: Sunday,August 19, 2018, 01:38:45 AM »
I have my window frames out atm and to me it didnt look like a gasket. it looked like a black sealant, similar to sikaflex but it was dried rock hard.
Im not sure what the proper sealant/ or gasket? to use is, but i would also like to know.
Currently restoring 54/1103
« Reply #4 on: Sunday,August 19, 2018, 05:49:27 AM »
This is what mine seems like except it is only partially there. The PO painted the car so I wasn't sure if he did it or if it was factory.
Offline TCS4605R
« Reply #5 on: Sunday,August 19, 2018, 07:02:21 AM »
I also have my window frames out.  They were held on by two pop rivets with some sealant for waterproofing.  The sealant had hardened over the years and was a pain to get out.  I plan on using clear 100% silicon to reinstall the frames in addition to the two pop rivets.
74 TCS - 4605R
Offline SwiftDB4
« Reply #6 on: Sunday,August 19, 2018, 08:09:25 AM »
Sorry for my original reply. I misread the question and thought you meant the seal between the quarter glass and the window frame.
Online dakazman
« Reply #7 on: Sunday,August 19, 2018, 01:07:07 PM »
I also have the frames out and mine were also pop riveted in place .
PPG products work great , pr1829 is a good choice for windshield and canopy’s. The PPG home page can guide you to a good choice, I also like there firewall sealants that can also be used and are easier to scrape off , and remain flexible and waterproof. Color choice is limited to gray, reddish orange, green and black , but they may have others. 2oz container is enough for both windows and is not reusable.
