Author Topic: Re-torque the head on a TC  (Read 873 times)
Stuleslie
  • Guest
« on: Thursday,August 16, 2018, 08:55:06 AM »
I have just completed putting the head back on after the gasket blew. I know that in the good old days you should re-torque the head after about a 500 mile run-in. Does everyone agree? Should I re-torque when hot?
Cheers
Stuart
Re: Re-torque the head on a TC
« Reply #1 on: Thursday,August 16, 2018, 09:05:54 AM »
I agree. I don't think it has to be hot, but I would loosen each nut (or is it a bolt?) a little and then tighten it back to spec. The reason for this is the coefficient of static friction is higher than dynamic friction.
« Reply #2 on: Thursday,August 16, 2018, 09:32:16 AM »
Mostly agreed.
Engine should be cold, or the torque will be different due to thermal expansion.
« Reply #3 on: Thursday,August 16, 2018, 10:18:38 AM »
After fitting a new head gasket, re-torque after the very first warm-up and complete cool down -- I wait until the next day.  Consult the manual as to whether further re-torques are necessary.
Re-torque:
- mark each bolt head for position -- I use a sharpie and mark a line parallel to the engine.
- follow the torque pattern.
- loosen the first bolt a half-turn using a breaker bar.*
- fit the torque wrench and turn to specified torque setting.
- it must at least go back to where it was, preferably further.
- move to the next bolt in the order and repeat.
Engines driven very hard will require re-torqueing even if it is not specified in the manual.  Not sure?  Mark and check the first bolt in the sequence.  Moves further than marked?  Do the rest as well.
* never, ever use a torque wrench to loosen a fastener.  Yes, I know some have a switchable ratchet, or a fixed beam, but don't do it regardless.  It may throw your wrench out of calibration.  Speaking of which, when was the last time you had your wrench calibrated?
Stuleslie
  • Guest
« Reply #4 on: Friday,August 17, 2018, 12:24:41 AM »
Thanks everyone for the advice.
I bought myself a new torque wrench just for this job as I realised my old one was only 40 years old!
Cheers
Stuart
