Coolant flow too fast vs. coolant flow too slow
.....This topic is often debated, with no definitive answer.
High-Flow water pumps and thermostats are often sold for aftermarket applications. ....Why, if too much coolant flow is bad??
Opinions about thermostat operation also differ. ....Some believe thermostats "cycle" at all times. ....Others believe thermostats cycle until engine temperature stabilizes at (or exceeds) thermostat opening temperature. .....If the coolant remains at 200*F with a 180*F thermostat, how can the thermostat possibly cycle??
Removing a thermostat is often said to be bad, but the installation of a flow restrictor is often recommended. ....Thermal efficiency and power is said to increase at higher operating temperatures, but temperature too high causes engine damage.
It is often said that too much flow does not allow the radiator to disperse the heat. .....If that is true, then coolant does not pick-up as much heat in the engine which needs to be dispersed, since the coolant is not in the engine as long, either.
Another theory suggests that the higher the difference between coolant temp and ambient air temp, the faster the heat exchange takes place. ....Conversely, while the temp exchange may be faster, there is a greater amount of BTU's which need to be cooled by the same ambient air temp.
I don't have answers, only more questions!
One needs to consider several factors in regard to engine temperatures. .....Adequate air flow through the radiator, whether vehicle is moving or stopped? ....Properly operating water pump (loose belt, worn impeller, etc)? .....Unrestricted coolant flow through the radiator? .....Suitable coolant composition? .....Adequate pressurization of the coolant system? .....Accurate temperature gauges and sensors? ...Etc., Etc., Etc. !!
