Author Topic: What's this switch for?  (Read 2368 times)
Re: What's this switch for?
« Reply #15 on: Friday,June 22, 2018, 04:02:08 PM »
I have the pump in the rad inlet hose.  It will negatively affect the flow through the heater core but that's not an issue as it never comes on at temps when I need heat.
Online GavinT
« Reply #16 on: Friday,June 22, 2018, 07:55:40 PM »
Thanks, John.
Are you using the Davies Craig digital controller?
If so, could you comment on the location you chose.
I note Davies Craig say to install the sensor in the thermostat housing or an in-line adaptor . . which presumably means downstream of the thermostat in our cars.
« Reply #17 on: Friday,June 22, 2018, 09:36:46 PM »
The EWP is controlled by the rad fan switch.  It only runs when I am sitting idling in traffic on a hot day.
« Reply #18 on: Saturday,June 23, 2018, 01:39:34 AM »
I used the D/C pump & controller in my TCS. Pump placement was beside the radiator, sensor placed in the thermostat housing. Worked.  Pump ran a couple minutes after shutting engine down.
Online GavinT
« Reply #19 on: Saturday,June 23, 2018, 06:40:49 AM »
Many thanks John & Andy.
Too easy . .
