Due to the current social and travel restrictions in place because of the C19 problem, I seem to have more time for the internet (as most of you, I am sure). Anyway, I would solicit any opinions about whether I should add the wings to my 62 ISH. I just do not know which way to go. Installation requires drilling holes in the body, so is pretty much irreversible.
The 62 was initially designed to resemble the, then new Europa. And after testing showed a lack of downforce, so it started to sprout wings. There were various wing configurations tried, but the "iconic" 62 look is the high mounted canards on the front, and split "boards" on the rear. Of course adding the wings gave downforce, but the trade-off was lower straight line speed.
Currently, I do not have the wings on the car, but I have constructed a set to see how it would look and if I liked the end result. I still do not know. The car really looks clean and uncluttered without them. Especially at the front. With the wings on, it breaks up the flow of the body line, and I really like the way it looks. The templates for the wings were given to me by Alex Bollinger, owner of one of the original cars.
Anyway, here is what I have come up with. Opinions are welcome?
Also, there was a question a while back about the storage area for the cars. The barn is 40' X 80'. It is split in half. 40 X40 for the cars and 40 X 40 for trailers and equipment. The workshop is a separate building 36' X 24'. I am running out of room, and I had to decide whether to sell something, add on, or go vertical. I chose the latter. I built a set of ramps to sit at 90 degrees to the long ramps of my old 4 post lift.
