I changed both output oil seals on a NG1 gearbox on my 72TC. N/s seal is ok but I have had the o/s seal off four times in trying to cure the leak. It is not just an odd drop but I estimate I lose 250ml every 50 miles. In the pic. there is a drip on the drain plug and a small pool of oil at the bottom edge of the castellated nut after a rest drive of 10 miles.
1. I have shimmed the drive shaft and there is no play there, the roll pin is very tight.
2. I have added sealer around the o-ring at the base of the gearbox splines
3. I have fitted a 35mm internal diameter seal instead of the nominal 36mm hoping that would seal better.
4. I have checked that the spacer between the inner bearing and the shims/driveshaft that covers the o-ring and makes a seal with the oil seal is not oval, measured to within 0.01mm.
The only thing I have found is that I can move the splined output shaft sideways by a few thou. Is this enough to lose so much oil? Has anyone any idea if there can be any play in the gearbox output bearing?
Any advise would be appreciated as I any going bonkers
Thanks Stuart
