Author Topic: Fault with 2 cylinders on a 807 Renault and Weber  (Read 704 times)
Offline Lyngeled
« on: Friday,April 27, 2018, 09:24:10 AM »
Hi
I have found a fault on this engine, I knew it wasn´t all ok (uses too much fuel), and there is two things I've noticed now.
I tried too adjust the idle mixture on all cylinders but on the two in front, 3 and 4, no changes was heard when the idle mixture screws were turned. Then there was click sound from the top where cylinder 3 and 4 are. I have heard it before but I thought it was normal. Now I think those two things are related.
Anyone have ideas?
Regards
Offline Lyngeled
Re: Fault with 2 cylinders on a 807 Renault and Weber
« Reply #1 on: Friday,April 27, 2018, 09:33:43 AM »
The click sound is not loud, so I hope it's not a big problem. I Haven't heard  it when driving. I can only hear it when standing beside the engine.
I thought that if nothing happens by turning those idle mixture screws the fuel must be delivered from a following curcuit. It's starting and running fine.
Regards
« Reply #2 on: Friday,April 27, 2018, 10:30:38 AM »
It is very difficult to diagnose without being there.  Carbs are always last on the list when making adjustments or troubleshooting.  First, make sure the engine is up to snuff:
- re-torque head (807 engines require regular re-torquing)
- adjust valves
- check compression
- check timing and advance
That's all good?
Now you can look at the carbs.
