Author Topic: WTB Tail lamps or tail lamp bases  (Read 1881 times)
Offline RoddyMac
« on: Saturday,March 31, 2018, 08:22:38 AM »
I'm in need of a pair of tail lamp bases for the amber and red tail lights.   I was all set to install the ones that came with my car and I discovered that the bases are for the all red lamps (single bulb).   Does anyone have a spare set?
« Last Edit: Monday,April 02, 2018, 07:48:46 PM by RoddyMac »
Re: WTH Tail lamps or tail lamp bases
« Reply #1 on: Saturday,March 31, 2018, 09:29:51 AM »
Did all federal Europas come with all red lenses? SJSportscars has the red and amber lenses and base.
https://www.sjsportscars.com/parts-and-accessories/SJ050M0024.htm
Also I think some of the Jaguar XJ models came with the red and amber setup.
« Reply #2 on: Saturday,March 31, 2018, 10:44:17 AM »
I have successfully drilled two holes, made up a divider, and fitted two bayonet fitting bulbs in federal tail lights.
The lenses are relatively cheap. The bulb holding bodies are not.
You can buy the bayonet fittings cheaply and glue them in new holes, fill up the old hole, and pop rivet the dividers in place.
Offline Rosco5000
« Reply #3 on: Saturday,March 31, 2018, 12:37:41 PM »
Have you tried William in Burnaby?  I only have the set on my S2 and a spare left side for my federal twin cam so I can’t help.
Ross
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Offline Rosco5000
« Reply #4 on: Saturday,March 31, 2018, 02:22:31 PM »
I sent you a PM about Doug Holbrow out in Abbotsford. He might have some housings for you.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Offline RoddyMac
« Reply #5 on: Monday,April 02, 2018, 07:00:19 PM »
Ross,
Thanks for reminding me about Doug, somehow I forgot about him.   As for checking with William, I'll send him a text.
Rod
