Author Topic: 54/1173  (Read 19341 times)
Re: 54/1173
« Reply #90 on: Friday,April 12, 2019, 04:27:38 PM »
GaryT, your door cards look great.
  I know full well the length of some honey do’s. Lol  keep moving forward!
« Last Edit: Friday,April 12, 2019, 06:46:01 PM by dakazman »
Offline BobW
Re: 54/1173
« Reply #91 on: Friday,April 12, 2019, 04:53:00 PM »
Making progress. Still on the fence about putting labels on, don't think they came from the factory like that, but still time to decide....
Early S2s like yours did not have labelled switches. Did labels start with the Type 65?
There is a possible downside to leaving them off. Three people spent several minutes this afternoon looking for the hood release on an early Elan. The owner, who had not been in it for several years, eventually remembered the two T-handles at the very top of the dashboard  ::)
Re: 54/1173
« Reply #92 on: Friday,April 12, 2019, 05:32:11 PM »
On the TCS, the headlight knob, dimmer knob, and fan and hazard warning switches were labeled. Also the heater/defrost controls were labeled.
Re: 54/1173
« Reply #93 on: Saturday,April 13, 2019, 04:47:13 PM »
Gary is a his what your inserts will look like?
Offline Gary t
Re: 54/1173
« Reply #94 on: Saturday,April 13, 2019, 05:21:26 PM »
Those look like great parts. Are they your craftsmanship?
No the door inserts will be upholstered, like stock but not black.
Gary Toffelmire
54/1173
Re: 54/1173
« Reply #95 on: Saturday,April 13, 2019, 05:23:28 PM »
Looks great, D'man! It looking like your car will be very interesting!
Re: 54/1173
« Reply #96 on: Sunday,April 14, 2019, 03:22:24 AM »
I am hoping to do a good enough job of cutting the hole for the cubby-hole that I can use the cutout for the door.
[/quote]
Hi Gary , Yes i made the dash and the inserts , i missed read your post and thought you were going  to use the wood in the big cutout.
Offline Gary t
Re: 54/1173
« Reply #97 on: Friday,April 19, 2019, 06:56:35 AM »
Does anyone have photos of how the original pump/wiper switch is mounted on the instrument panel?
Gary
Gary Toffelmire
54/1173
Offline Gary t
Re: 54/1173
« Reply #98 on: Friday,April 19, 2019, 06:58:01 AM »
Or a description?
Gary Toffelmire
54/1173
Re: 54/1173
« Reply #99 on: Friday,April 19, 2019, 07:15:40 AM »
For some reason I can't view a PDF on my iPad but there is probably a picture of the dash in the owner's manual here: http://www.lotus-europa.com/manuals/s2owner/index.htm
Offline Gary t
Re: 54/1173
« Reply #100 on: Friday,April 19, 2019, 08:00:04 AM »
I know where it goes but the old panel I am using for a pattern has a giant hole in that location, and the mounting shaft on the switch is .5 inch.
Gary
Gary Toffelmire
54/1173
Offline Gary t
Re: 54/1173
« Reply #101 on: Saturday,April 27, 2019, 07:59:25 AM »
Ok another question about mounting things on the instrument panel. How have people fastened the face level vents in? The manual talks about just using the air duct, but that does not seem that secure to me.
Also I am still interested in washer pumps. How are they mounted can the pump be made to work?
Gary Toffelmire
54/1173
Offline gideon
Re: 54/1173
« Reply #102 on: Saturday,April 27, 2019, 09:57:22 AM »
The face level vents have a plastic collar that screws on from behind the dashboard.  There are slots in the collar and pegs in the vent that fit into the slots.
Offline Gary t
Re: 54/1173
« Reply #103 on: Saturday,April 27, 2019, 01:51:33 PM »
Ok thanks I have no rings. The PO has built a replacement panel very poorly and the rings no longer exist.
Gary
Gary Toffelmire
54/1173
Offline Gary t
Re: 54/1173
« Reply #104 on: Monday,April 29, 2019, 09:41:01 PM »
Have any of you LHD people swapped the dip dwth a direction indicator switch in order to get the indicator switch on the left side of the steering column?
Gary
Gary Toffelmire
54/1173
