Author Topic: zetec flywheel question  (Read 521 times)
Offline mcooper
« on: Thursday,March 15, 2018, 01:40:45 AM »
I've been looking for best flywheel to use with zetec to tcs install. found on burton power and retrofords, a flywheel for zetecs that's are made to fit up to rwd t9 gearboxes. i believe they could solve two problems. first starter spacing then second  may fix clutch release bearing relation. the pressure plate surface is further from engine. such as is on lotus, Kent and pinto engines. the flywheels are drilled to use pinto clutches.  i hope someone out there has used or has any thought  if these flywheels and clutch Assembly will work
vin#3962r
