Brian, BRILIANT! I like your design and will certainly incorporate it to prevent further issues.
But the plot thickens: Just as I thought I'd be lucky and not resort to extream messures, the DPO and his associate (read a collision specialist who obviously wasn't) changed everything for the worst.
I should have known better as there were some evidence of prior damage: missing pin stripe on the right fender (wing), cracked sill valance, said valance held in place at the ends with screws, not rivets...and only (1) nut on the upper and lower hinge bushings! Some kind of half shim on top??? And this pin (right side) is in much worse condition than the the left...aha, due to an ill fitted wheel arch closure. Looks like plan 'B', as in 'when in doubt, cut it out. The original plan was to loosen the hinge pins so I could remove the doors easily while the rest is prepped for a respray later this year (late Fall) and work on the doors separately. I'm not in a rush. I'm going to enjoy driving it for the time being and apply penetrating fluid periodically. I will definitely replace the hinging and, of course, employ Brian's solution. I'll update on the progress as appropriate.
Gerry
