Author Topic: rear hubs  (Read 876 times)
Offline brucelotus26r
rear hubs
« on: Sunday,March 11, 2018, 07:40:59 AM »
I'm looking to put my rear hubs together and do I need  Locquic primer grade T & Loctite 635 ??
Or is there something else I'm only putting 2 hubs together and this dose not look like something I can get at the Auto parts store
and the stuff is not cheep?
Re: rear hubs
« Reply #1 on: Sunday,March 11, 2018, 09:14:37 AM »
I believe you can get small bottles of the Loktite from r.d. They may have the primer, too. I don't remember using the primer.
Offline SwiftDB4
Re: rear hubs
« Reply #2 on: Sunday,March 11, 2018, 10:44:05 AM »
Loctite 635 is the green compound. I do use that for maximum bonding and high temperature since I track my Europa running on slicks and disc brakes. Loctite 272 (red) is probably adequate for street use, costs less, and can be bought at auto parts stores. You don't need the primer. Just clean all parts well.
Re: rear hubs
« Reply #3 on: Sunday,March 11, 2018, 10:49:46 AM »
When Dave Bean was building my motor, he suggested I use red Loktite to build my hubs. I understand that that the green 635 is specifically for filling the voids between things like splines and such rather than just be a "glue." They both require heat to disassemble the parts. I think I'd use 635 regardless of the expected driving.
I believe there is a Loktite cleaner but I've always just used lacquer thinner.
« Last Edit: Sunday,March 11, 2018, 11:25:38 AM by BDA »
Re: rear hubs
« Reply #4 on: Sunday,March 11, 2018, 12:56:58 PM »
635 is slow set so it gives you time to carefully assemble everything.  I think that is a very important feature.
Re: rear hubs
« Reply #5 on: Sunday,March 11, 2018, 04:27:37 PM »
I couldn't find 635 locally so I bought my small bottle from RD.  Make sure you clean the splines on both the axle shaft and the inside of the hub as there will be residual left over loctite bedded in between the splines and the new Loctite won't adhere as well.
