Author Topic: Europa brakes  (Read 4688 times)
Re: Europa brakes
« Reply #15 on: Wednesday,March 14, 2018, 12:19:25 PM »
Thinking of doing this myself. Would love to know how much improvement they make.
 Has anyone else done this, and can you recommend it?
If the boosters have failed on your TCS, you know what terror is when attempting to brake hard for an unexpected stop. A smaller bore M/C makes a huge difference in braking. I had the Nissan F10 M/C installed by the PO on my TCS (now sold)and it was outstanding in braking feel and stopping power. The Spitfire M/C should be similar with slightly longer pedal travel, also:
Offline brucelotus26r
Re: Europa brakes
« Reply #16 on: Tuesday,March 20, 2018, 03:35:58 PM »
Another bridge crossed. Sunday I took my Eupora out for a test drive after rebuilding to rear suspension installing all new brakes new Spax shocks a .70 brake master and new lines to remove booster.
Re: Europa brakes
« Reply #17 on: Tuesday,March 20, 2018, 03:44:59 PM »
Congratulations  :beerchug: What were your impressions of the car during the drive?
Re: Europa brakes
« Reply #18 on: Tuesday,March 20, 2018, 05:00:42 PM »
Will that mc work with an S2?
Re: Europa brakes
« Reply #19 on: Tuesday,March 20, 2018, 05:34:52 PM »
Congrats Bruce. Can’t wait to drive your Europa again to experience the difference.
Re: Europa brakes
« Reply #20 on: Tuesday,March 20, 2018, 07:12:00 PM »
Congratulations Bruce! I'm sure it lived up to your expectations!
Re: Europa brakes
« Reply #21 on: Tuesday,March 20, 2018, 07:12:54 PM »
That one might have metric fittings.
Re: Europa brakes
« Reply #22 on: Wednesday,March 21, 2018, 04:57:45 AM »
Thanks JB , the reason is there is a s2 girling tandem brake cylinder for sale on eBay, however somewhat pricy....I read other articles on other mc that have been installed but just want to consider other options.
Thanks Bruce for posting.
Re: Europa brakes
« Reply #23 on: Wednesday,March 21, 2018, 06:06:26 AM »
The original cylinder will have the outlets facing the right way and simply bolt up to the lines you already have.  The outlets on this cylinder face the other way so you will have to make up extensions, or new lines to suit.  All the fittings, metric and imperial, are readily available from British parts suppliers.
Re: Europa brakes
« Reply #24 on: Wednesday,March 21, 2018, 06:12:15 AM »
That small cap Spitfire M/C is the one I used for my article. The outlet ports are metric threads. For the S2, it's simple enough to make up two new lines to run from the M/C to the three way unions. .
Re: Europa brakes
« Reply #25 on: Wednesday,March 21, 2018, 08:33:53 AM »
I think it will work will on any Europa you will have to make some new lines.
I have a good pedal and the brakes work very good.
I would like to have tires with more grip as my new Kumho TA11 leave something more to desired ?
Re: Europa brakes
« Reply #26 on: Thursday,March 22, 2018, 03:50:58 PM »
Snow day project
