Guys,
Having got an axle nut off, I found three odd details, and invite your comments:
First, I don't have any D washers under the axle nuts. My outboard drive axle shafts are round in cross section, with no flat on the end for the D washer to engage - I assume outboard drive axle shafts have a flat to correspond to the flat on the D washer, yes, no? Anybody got a pic?
Second, I have oil seals on the outboard (yes, outboard) side of each bearing housing. These shouldn't be here according to the parts manual.
Third, someone drilled a hole in each bearing housing and installed a zerk fitting.
From 2 & 3, I'm assuming a PO replaced the original sealed bearings with non-sealed bearings and modified the system to allow periodic greasing. I guess I'll eventually tear this all apart and put in the correct bearings.
(Mike, yes, I still have the Speedster, had it since '73. It's now undergoing a complete restoration. It's a beautiful car, almost a piece of art, but, frankly, these cars are way overvalued, IMHO. I've sometimes thought of selling it and getting an Elite and a 23B
Regards
Rick
