Author Topic: crossflow question  (Read 1033 times)
Offline califkid_66
crossflow question
« on: Friday,December 15, 2017, 07:06:00 AM »
i just bought a s2 federal type 65 it as the renault wedge 821-30 in it but the guy gave me an extra engine  it as a crossflow head with delortos  but on the plate is written A7L so im aa bit confused and would it fit my 336 gearbox thanks Claude
Re: crossflow question
« Reply #1 on: Friday,December 15, 2017, 07:36:41 AM »
Sorry I can't help you with your question, but I can do this:  :Welcome:
Offline califkid_66
« Reply #2 on: Friday,December 15, 2017, 07:46:10 AM »
thanks !!  i tried posting pictures but the files are to big
« Last Edit: Friday,December 15, 2017, 07:48:50 AM by califkid_66 »
Offline RoddyMac
« Reply #3 on: Friday,December 15, 2017, 07:53:33 AM »
califkid_66,
Good to see you've joined the forum, is this is pic you're trying to post (stolen from your post on the Locost site):
Rod
« Reply #4 on: Friday,December 15, 2017, 08:57:51 AM »
There are lots of ways to resize pictures. Here is one way: http://www.lotuseuropa.org/LotusForum/index.php?topic=1379.0
« Reply #5 on: Friday,December 15, 2017, 10:47:48 AM »
I have a spare A7L turbo motor and told by the seller that came from the Turbo Fuego here in the US.
The bell housing from the 336 will not fit the A7L. The bell housing is a bit too shallow causing the pressure plate to contact the bell housing. You will need to find a deeper Renault bell housing or see if the clutch from the 336 will work.
« Last Edit: Friday,December 15, 2017, 10:50:53 AM by Grumblebuns »
Offline califkid_66
« Reply #6 on: Friday,December 15, 2017, 11:36:10 AM »
thanks for posting the picture of my engine!
ok so that solves a mystery when i bought the car it had the original engine match numbers and the guy gave me the crossflow with it i noticed there was damages on the rear wing the guy told me its when they changed the engine so its probably he tried to put the crossflow and didnt work so i wont make the same mistake  the 821 runs great and i have a few things to fix like adjusting the doors and changing the windscreen i have a new one came with the car im only missing the surround its a glued one   so im shopping for that and if someone has a dustshield for the tranny it would be nice or else ill have to fab one
« Reply #7 on: Sunday,December 17, 2017, 06:49:27 AM »
Calikid 66,
Welcome to the forum.
I normally take a pic with my phone and send it to my email , my phone asks ,what size , at that point choose something smaller than 1 mg, then save that image. When adding attachment direct your post to that location ,it will then load to site.
« Reply #8 on: Sunday,December 17, 2017, 06:57:14 AM »
Yes, the 336 bell housing is shallow and you would have to fit the smaller 336 flywheel and clutch assembly to make it work.  Some more info can be found in these pdfs:
http://www.lotus-europa.com/manuals/s1misc/PFEngineering.pdf
http://www.lotus-europa.com/manuals/s1misc/s1hemi.pdf
