Author Topic: Bright Lights, Big City  (Read 2889 times)
« on: Tuesday,December 05, 2017, 09:06:30 AM »
I tried modern LED headlights but I just didn't like the look.  So I went back to the Marchal Amplilux headlights paired with a single HID spot behind the front grill.  That gave me the period look with good high beams but the low beams left a lot to be desired.  So out came the spot and in went Hella HID 90 mm modular headlights behind the front grill instead.  They "ain't" cheap but they sure are bright!
https://jbcollier.smugmug.com/Lotus-Europa/i-DR9SWdj/A
« Last Edit: Tuesday,December 05, 2017, 09:17:32 AM by jbcollier »
Re: Bright Lights, Big City
« Reply #1 on: Tuesday,December 05, 2017, 09:25:01 AM »
I've been thinking about LED headlights. What about the look didn't you like? Did they have fan cooled electronics? Which ones did you use? Did you find them bright enough?
« Reply #3 on: Tuesday,December 05, 2017, 11:19:17 AM »
John, hard to tell but are the Hellas the same type used by Left Angle in his post?
Offline EuropatcSPECIAL
« Reply #4 on: Tuesday,December 05, 2017, 11:53:57 AM »
Great shot, looks the business
« Reply #5 on: Tuesday,December 05, 2017, 12:24:27 PM »
His are halogens I believe.  Clever install but I just don't care for the look myself.  The HIDs are much, much brighter, lower wattage as well.  Low beam is just a shuttered high beam so there is none of the typical HID lag when switching from one beam to the other.
Offline lotusfanatic
« Reply #6 on: Tuesday,December 05, 2017, 11:31:58 PM »
Hi JB,
I love the photo!
(what year is your car?)
« Reply #7 on: Wednesday,December 06, 2017, 06:21:32 AM »
Early '68 S1b
« Reply #8 on: Friday,December 08, 2017, 05:23:10 AM »
beautiful!
I must look through your posts as you’ve probably written about it before..
