Author Topic: Balance beads  (Read 1265 times)
Balance beads
« on: Monday,October 23, 2017, 09:35:37 AM »
Has anyone used balance beads this on their wheels? (http://www.dynabeads.co.uk/).  I have had a difficult time getting consistent balance on my Lotus alloys since there is a very poor machined centers on the wheels for the balance machine cones to fit to.  I bought a static balancer from Harbor Freight but find it to be somewhat inconsistent as well for the same reason.
Re: Balance beads
« Reply #1 on: Monday,October 23, 2017, 09:59:25 AM »
I'm not disputing your analysis, but I'm wondering if you're might be falling victim to your lug holes getting wallowed out. It's a known issue with Lotus Brand wheels.
Offline Rosco5000
Re: Balance beads
« Reply #2 on: Monday,October 23, 2017, 11:11:32 AM »
If your rims are centering on the hub on the center of the rim no matter how good you balance the tire it will never spin true.  I would get you rims machined true and have a hub centric ring made to line everything up between you wheel hub and rim.  That way you can get a good balance and then have it run true on the hubs.  No real easy solution here I'm afraid.  you can't fix a fundamental flaw in the setup with balancing weights.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Re: Balance beads
« Reply #3 on: Monday,October 23, 2017, 12:36:08 PM »
IIRC, the centre of the Dunlop mags are not machined so you can't use them as a reference point when balancing or mounting the wheels.  As mentioned above it would be fairly simp to have the centres machined up which would help a great deal with balancing the wheels.  It is simple to centre the wheels when mounting them on the vehicle is you use two regular Triumph lug nuts to locate the wheel first and then secure the where with the original lug nuts on the two remaining studs.
Re: Balance beads
« Reply #4 on: Monday,October 23, 2017, 12:41:43 PM »
Lotus supplied balanced drums for the rear brakes on the Europa after experiencing balance issues.  Replacement drums from British parts suppliers are NOT balanced.  I was having a heck of a time with shaking from the rear wheels.  I fit the drums to spare rear hubs and mounted them to tapered centres supported on ball bearings.  I removed a considerable amount of material to achieve proper balance, ranging from 80 to 200 grams!  Shake is now gone.
Re: Balance beads
« Reply #5 on: Tuesday,October 24, 2017, 09:51:55 AM »
FYI, here is a post I made last year whilst experiencing similar problems.
Re: Balance beads
« Reply #6 on: Tuesday,October 24, 2017, 11:22:19 AM »
Trevor,
I don't see your post from last year.  I searched but no luck.
Re: Balance beads
« Reply #7 on: Wednesday,October 25, 2017, 08:30:32 AM »
