Author Topic: Renault R16 gasket set  (Read 3001 times)
Offline Cortinalodi
« on: Thursday,October 05, 2017, 01:47:01 AM »
Looking for complete gasket set or web site I can order one. Any help appreciated
Thanks m Drouin
Cortinalodi@yahoo.com
Offline lotusfanatic
Re: Renault R16 gasket set
« Reply #2 on: Thursday,October 05, 2017, 06:22:24 AM »
Contact Steve Veris in Dayton, Ohio.
Gaskets for Renault Engines - 8/1/17
•Cross flow head gasket set - $80.00
•Cross flow intake manifold gaskets - $6.25 each
•S1 Intake manifold gasket - $18.00
•Oil pan gasket, cork, new production - $18.00
•S1 or S2 head gasket set - $85.00
•S1 or S2 complete overhaul gasket set - $145.00
•Large water pump gasket $10.00
•Shipping via USPS 1st Class Parcel rates to USA, Canada and overseas
•Contact steve.veris@sbcglobal.net
Offline shootingsight
    • Lotus Europa Community
« Reply #3 on: Tuesday,October 31, 2017, 03:00:17 PM »
Just for info, the Lotus head has aadditional holes drilled in it to allow greater flow for improved cooling.  If you buy a Renault head gasket, you need to punch corresponding holes, or else you will overheat.  Ask me how I know .... :-)
« Reply #4 on: Tuesday,October 31, 2017, 06:00:09 PM »
Do you have any pictures showing the extra holes?  Just curious as this is the first time I have heard of it.
Offline Cortinalodi
« Reply #5 on: Thursday,November 16, 2017, 12:43:22 PM »
Thanks Steve
got gaskets and everything I need to pull the engine apart a see what 20 years of sitting has done.
Still looking for a rebuildable distributor. But I have an electromotive set up I can use if I need to.
M Drouin
« Reply #6 on: Saturday,November 18, 2017, 07:34:11 AM »
I do not have pictures.  I removed the head 3 times when it overheated in the first 15 minutes, convinced the problem was elsewhere.  On try #3 is saw green dots on the gasket where coolant had been blocked.  As I recall, there are about 8 or 10 1/4" holes in the head, if you look at the bottom of the head, you'll see them.
Offline Cortinalodi
« Reply #7 on: Saturday,November 18, 2017, 10:23:52 PM »
I have made it a habit to compare old with new as part of the process! But I will take a close look at the holes on old head gasket.
Thanks
