Author Topic: Minilite wheels  (Read 2059 times)
Offline Haysie
Minilite wheels
« on: Monday,October 02, 2017, 03:02:07 AM »
Hi guys,
I have an opportunity to buy a set of used Minilite wheels which are in pretty good condition, however the lug holes are 100mm apart. I can buy 25mm wheel spacers to fit the rims onto the S2 but that might push the wheel out too far.
Is it worth it?
Re: Minilite wheels
« Reply #1 on: Monday,October 02, 2017, 05:40:27 AM »
Minilites are one of the most copied aftermarket wheel rims out there.  Buy ones that fit out of the box.
Re: Minilite wheels
« Reply #2 on: Monday,October 02, 2017, 05:42:38 AM »
Do you know the back space for the Minilites? This could along with the width of the wheel spacers give a good idea if the wheels will fit. The stock S2 back space is 4", if I remember correctly. They had better be really, really cheap to go this route.
Offline Gmg31
Re: Minilite wheels
« Reply #3 on: Monday,October 02, 2017, 06:43:34 AM »
Be aware that it is very difficult to buy replacement wheel nits for genuine old Minilites.   Even Minilite don't do them anymore!
Re: Minilite wheels
« Reply #4 on: Monday,October 02, 2017, 07:23:53 AM »
Unless you replace the wheel studs for metric ones.
Offline Gmg31
Re: Minilite wheels
« Reply #5 on: Monday,October 02, 2017, 02:23:02 PM »
That would have been useful to know 2 years ago. I did get some in the end but they had to be fitted with collars.
Offline Haysie
Re: Minilite wheels
« Reply #6 on: Tuesday,October 03, 2017, 02:37:29 AM »
Thanks for the replies. Might give them a miss.
Re: Minilite wheels
« Reply #7 on: Tuesday,October 03, 2017, 04:07:10 PM »
Standard Toyota alloy wheel nuts fit the Minilites, but not the wheel studs.
Offline Gmg31
Re: Minilite wheels
« Reply #8 on: Wednesday,October 04, 2017, 05:19:52 AM »
Having said all of the above if they are genuine period minilites and you can get them at a reasonable price then they are still worth getting.  I had mine powder coated and they look fantastic. I can probably find the email address of the guy that supplied my wheel nuts if you want it.
