It's kind of pathetic the little work I've done on my rebuild. I have found renewed interest, energy and time so I am jumping back in and am going to finish it this time. (my wife is threatening to "help" again
). My problem when I've gone to work on it is, despite taking good care during disassembly, I keep finding I'm missing a part - typically the third thing I go to install. Then I get frustrated. I'm trying to lay all of the parts out now it will take to complete the engine rebuild so I can make one order and then finish it.
Need an adapter for the end of the jackshaft so I can attach the jackshaft sprocket and then the water pump assembly. Can't locate the bolts for the rear oil seal retainer either. I think I'm generally good otherwise.
I did have a question about fasteners in general - if I need a bolt here or there, I'm guessing I don't just run over to the local big box hardware store. Seems like they are the wrong material. Do I just order bolts from a parts catalog or is there some other source? I'm guessing most of the bolts are steel.
