I don't know how many members have four posts lifts, but I thought the members should be aware of a potential problem. I have a (now defunct) Autolifters four post lift. Had it for 20 years. Recently I had my Jaguar on it and a couple inches off the floor I heard a loud snap. One of the cable guide pulleys shattered. Autolifters used a "plastic" guide pulley with a brass insert. The brass bushing is not held firmly enough in place and it can break. Then shortly thereafter the pulley also breaks. Most of these four post lift work the same way, and it would be a good idea to check your pulleys. Backyard Buddy uses a 4" diameter 3/4" bore pulley that is exactly the same size as the "plastic" pulleys used by Autolifters. BBs' pulleys are steel with a brass bushing. They should last forever. I changed out all the pulleys for about $300.
Had this happened when the car was near the top, could have been really serious.
