Author Topic: Starter motor options / interchangeability S2  (Read 1173 times)
Offline elcaminokid
« on: Friday,July 28, 2017, 11:09:44 AM »
hi all,
has anyone tried to fit a newer Renault starter motor to their S2?
mine sits very close to the exhaust, so looking for options for a small size starter (it's hard to start when the engine is hot and not a lot of clearance for a heat shield.
thanks
Re: Starter motor options / interchangeability S2
« Reply #1 on: Friday,July 28, 2017, 11:14:30 AM »
I would think you'd be able to find a gear reduction starter. They are usually smaller than the old '60 - '70's starters and they have a lot more torque at the flywheel.
« Reply #2 on: Friday,July 28, 2017, 02:58:11 PM »
rdent.com has them.  Probably Banks as well.
Offline RoddyMac
« Reply #3 on: Friday,July 28, 2017, 03:05:09 PM »
Try AngloParts seeing as you're in Belgium.  They appear to be a Gustafson starter dealer http://www.gustafsonmachine.com/.  Keith seems to supply just about everybody.
« Reply #4 on: Friday,July 28, 2017, 05:34:25 PM »
Do Anglo-Parts carry Renault parts?
Offline elcaminokid
« Reply #5 on: Sunday,July 30, 2017, 08:35:11 AM »
Thanks for the replies so far guys!
I'll check around based on your sugestions
« Reply #6 on: Tuesday,August 01, 2017, 05:37:18 AM »
Also check out" powerlite", they make reduction gear starters. you may find a local stockist.
http://www.powerlite-units.com/products/stater-motors/
I used one in my TC
