Author Topic: Help identify hole in chassis  (Read 1253 times)
Offline Runningwild
« on: Monday,July 24, 2017, 06:31:49 PM »
Bottom hole is for seat belts. What's the other hole for? They both line up with holes in the body.
Thanks tom
Re: Help identify hole in chassis
« Reply #1 on: Monday,July 24, 2017, 06:41:42 PM »
There's nothing there on the TC and I doubt there's anything there on the S2. The PO must have mounted something there. Who knows what.
Offline Runningwild
« Reply #2 on: Monday,July 24, 2017, 08:00:10 PM »
Thanks
« Reply #3 on: Monday,July 24, 2017, 11:11:12 PM »
Is it just a hole, or does it have a threaded nut welded on the tunnel side?
Offline nigelc
  • S2 54 under restoration and S2 47 style
« Reply #4 on: Tuesday,July 25, 2017, 03:46:36 AM »
I think the lower of the two is the seat belt mounting point ?... not sure about the other , will check on mine when i get home later .
Offline Gmg31
« Reply #5 on: Tuesday,July 25, 2017, 05:17:38 AM »
lower one is def seat belt mounting point.  Upper one appears to have been bashed through quite violently by a prev owner, perhaps some sort of  DIY attachment.
Offline Runningwild
« Reply #6 on: Tuesday,July 25, 2017, 05:29:48 AM »
No threads on the upper hole in the chassis. I'll glass over the matching hole in the body.
« Reply #7 on: Tuesday,July 25, 2017, 02:32:55 PM »
If the hole is not threaded it is very unlikely to be original factory made.
I cannot think of anything you could fit there so high up in the drivers (LHD?) side of the car.
