Author Topic: installing a new speedo cable - never that easy  (Read 1777 times)
Offline Europa73
« on: Saturday,July 08, 2017, 09:22:19 AM »
Hi all,
Got another issue this week.
The speedo cable broke.  Looks like the previous owner had had some issues with it as the retaining sleeve going into the gearbox was split.
I ordered one from Banks – came super quick.
But – it looks different from the one on the car.
The car is a TCS with a five speed box.
The new cable has a flat tab that goes into the gearbox  - but – when I took the old one out the end of the cable was a slightly different shape and had no flat tab end, only the square cable same as goes into the speedo – please see the pics.
Could it be that the slightly different shape does not make any difference?
And
Could the flat tab still be in the gearbox? If yes, do I just pull it out with a long nose pliers? Just a little nervous at the thought of just pulling at things in the gearbox.
Any advice would be greatly appreciated.
Cheers,
Re: installing a new speedo cable - never that easy
« Reply #1 on: Saturday,July 08, 2017, 12:10:00 PM »
Does the new cable fit into the gearbox easily? The flat tab may just be a variation on the square inner cable.
Offline Europa73
« Reply #2 on: Saturday,July 08, 2017, 03:07:03 PM »
Hi there,
Unfortunately not.
« Reply #3 on: Saturday,July 08, 2017, 09:45:21 PM »
I would have to check because it's been many years since I replaced my cable, but I'm sure the end was much cruder than the new cable you have there. I have an image in my mind of the internal cable being swaged into a square end and that's what slotted into the (352) gearbox.  I had a quick look for pictures and found this on the SJS website which says it's for the 352/365 box. I'm wondering if the 336 box is different  and maybe that's what you have ?
Stuleslie
  • Guest
« Reply #4 on: Saturday,July 08, 2017, 11:09:47 PM »
Just fitted my speedo cable the other day, purchased from Richard and it definitely has a square end for the five speed gearbox. Sorry but it Looks like you have the wrong cable.
Offline Europa73
« Reply #5 on: Sunday,July 09, 2017, 06:38:47 AM »
Ugh -
Yep it looks like the wrong cable :-(
Offline Gmg31
« Reply #6 on: Tuesday,July 11, 2017, 04:24:11 AM »
 Mine is a square cable that goes into a 90 degree fitting first and then goes into the gear box via the flat fitting.
