Author Topic: #460002 - Restoration  (Read 102074 times)
Offline Serge
    • Sleurs Motorsport
Re: #460002 - Restoration
« Reply #270 on: Wednesday,March 20, 2019, 11:33:46 PM »
Thanks for all the nice words!
There are some more videos coming, trying to do one every two weeks.
I agree about the tapered threads, would do it differently next time. But will see how this one works first.
3D printed intake manifolds:
https://youtu.be/zIVduZnAFRg
Oil pump:
https://youtu.be/xKi4X7PKAHo
Serge
Offline Serge
    • Sleurs Motorsport
« Reply #271 on: Tuesday,April 09, 2019, 12:54:54 PM »
A long video this time!
A lot of work on my cylinder head!
https://youtu.be/Q7el4SiTRkY
« Reply #272 on: Tuesday,April 09, 2019, 02:06:58 PM »
Another great video, Serge! When you were lapping the valves, it looked like there was a small step from the roof of the chamber to the seat of the exhaust valve. Was that a real step or was it something that you need there?
« Reply #273 on: Tuesday,April 09, 2019, 09:05:14 PM »
A proper valve seat is roughly 2mm in width and hits the valve on on the outer third of its machined face but not all the way to the edge.  I use three cutters to refinish the seat and trim it to the correct width and diameter: 45°, 30° and 60°.  If you just lap in your valves you end up with a very wide seat that will not seal, nor last, as well.
« Reply #274 on: Tuesday,April 09, 2019, 09:06:04 PM »
... very nice work opening up and blueprinting the chambers!
Offline Serge
    • Sleurs Motorsport
« Reply #275 on: Wednesday,April 10, 2019, 03:22:20 AM »
The valve seats have a 3 angle valve job, so they have 3 different radius' on the valve seat, only one will actually seal the valve. The other two give a better radius to flow.
The step on the roof of the chamber is something that was already there. In some places I tried to remove it a litlle bit, but I didn't want to get too close to the seat with the carbide cutter.
Serge
« Last Edit: Wednesday,April 10, 2019, 03:24:55 AM by Serge »
« Reply #276 on: Wednesday,April 10, 2019, 05:42:53 AM »
Then why all the lapping?
I will very lightly lap a valve at the end, but that's it.
Offline Serge
    • Sleurs Motorsport
« Reply #277 on: Wednesday,April 10, 2019, 09:45:44 AM »
Because I was unsure on how well the valves sealed. In my mind it was better to quickly lap to make sure the surfaces sealed.
Serge
« Reply #278 on: Wednesday,April 10, 2019, 10:57:20 AM »
After the seats are ground and the valves refaced or replaced -- I always fit new exhaust valves -- I use bluing (AKA: Prussian Blue) to check seat contact.  Three dabs around the seat, spin the valve and all is revealed.
I'm old school, so once I'm happy with that, I very lightly do a valve lap at the end.  Most machine shops cringe when I say this and I think they are probably right.  I started with high-speed, valve seat grinders, now they use special cutters, much more precise.
« Reply #279 on: Wednesday,April 10, 2019, 11:14:30 AM »
   Nice work on the videos, the body is coming along nicely.
The head work was amazing and Can’t wait to see more videos.
« Reply #280 on: Wednesday,April 10, 2019, 11:46:23 AM »
I don't remember why we had this discussion but back when I was running my Midget racer in the '70s, a machinist I used for the critical stuff like the head, told me that if I was worried about quality of a valve's seal after a quality valve job had been done, to "freshen" the seal with something with very light and fine grit like toothpaste. He wanted to make sure I used the minimum grit possible.
I think your blue technique to determine if there is a problem in the first place is a great practice. if there isn't a problem, don't try to fix it.
Offline Rosco5000
« Reply #281 on: Wednesday,April 10, 2019, 01:10:35 PM »
Serge!  I just saw your Instagram video, I hope the car is alright after its half somersault!
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Offline Serge
    • Sleurs Motorsport
« Reply #282 on: Friday,April 12, 2019, 01:47:54 AM »
Only a small crack where the windshield frame joins the roof, and this needed to be strengthened anyway (per Johns advice). Could have been a lot worse!
Modifying the tip over jig as we speak, don't want that to happen again!
Edit: the jig now works as intended. Will update with video later
Serge
« Last Edit: Friday,April 12, 2019, 10:12:48 AM by Serge »
Offline Rosco5000
« Reply #283 on: Friday,April 12, 2019, 03:21:12 PM »
I'm glad you made the jig work, good idea to get to the underside.  Good thing you and the car are mostly in one piece.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Offline Serge
    • Sleurs Motorsport
« Reply #284 on: Saturday,April 27, 2019, 10:16:03 AM »
I decided that I wanted high end shocks, didn't want to go for a 'lesser' damper after spending 8 years and all this money on the Europa. In the end I had Simon at Raceshocks.uk spec me custom Nitron coilovers. Ride frequencies of 1.74 in the front and 1.57 in the rear with a progressive spring in the rear.
All aluminium 40mm body, monotube design, single adjustable. Very high spec! Only downside is price, and that they have to be looked after. Is essentially a race damper, so service intervalls are about every 2 years. But they are built and valved for my specific application.
Details are in the video.
Now let's try to finish the damn car so I can drive it!
https://youtu.be/HUBq9mz61_E
Serge
