Author Topic: 0453R Rockledge Florida  (Read 30635 times)
Re: 0453R Rockledge Florida
« Reply #15 on: Friday,September 08, 2017, 04:40:15 PM »
Busy week on tiki heads and dealing with hurricane prep.
These have been sealed and painted. A little off topic but
Just life.
« Reply #16 on: Friday,September 08, 2017, 04:45:55 PM »
Stay safe, dakazman. Irma is going to be one nasty bitch! At least she's weakened a little. Where in Florida do you live?
« Reply #17 on: Friday,September 08, 2017, 05:49:49 PM »
Dak - stay safe down there! And those tiki heads are the bomb! what are they constructed of? Your daughter carved them? Great work!!!
« Reply #18 on: Saturday,September 09, 2017, 04:10:50 AM »
On the east central part of state just south of cape canaveral.
  Daughter drew them and painted, I carved the styrofoam with a hot knife
Sanders, files. Then they were hot sealed. Daughter Still painting second and having fun
Doing it.
« Reply #19 on: Saturday,September 09, 2017, 05:41:33 AM »
They look great!
I was wondering if Styrofoam. Family business was florist & greenhouses, so where I grew up. Always carving something out of it. Styrofoam is a good medium to work in.
« Reply #20 on: Sunday,September 17, 2017, 06:25:34 PM »
After waiting a week or so I received the wrong inner bearings for the front hubs.
Does anyone have the correct part number ?
« Reply #21 on: Sunday,September 17, 2017, 09:01:39 PM »
Same as a Triumph Spitfire and TR6.
Offline Bodzer
« Reply #22 on: Monday,September 18, 2017, 02:16:08 AM »
I think it's this:
Inner bearing race 07100S
Inner bearing journal 07210X
Outer bearing race 03062
Outer bearing journal 03162
Triumph Herald and Spitfire 1959-1974
I hope you're ok after Irma.
Regards,
Pete
« Reply #23 on: Monday,September 18, 2017, 06:58:29 AM »
Don't know if you have this, a Golden Gate Lotus
parts cross reference. It may help sometime.
http://gglotus.org/ggpart/europacr.htm
« Reply #24 on: Monday,September 18, 2017, 10:28:37 AM »
Thanks guys,
Yes neighbors and I all fine but a lot of cleanup.
Purchased two inner bearings off eBay and both no good.
Beck at key 0513843 to small and master pro pta-13 to large. So suspension work moving slowly which gives me more time to fiberglass wheelwell inserts in for the close out panels.
Also received my 821 engine gasket set today so will be getting block crank liners to machinist.
« Reply #25 on: Monday,September 18, 2017, 10:41:50 AM »
That is a lot of cleanup piled up!
« Reply #26 on: Monday,September 18, 2017, 02:16:44 PM »
There not much left for the next one to take down.
Raining again , just when it looked like we were going to dry out.
Not like flooding but mosquitoes are going to be killer..
« Reply #27 on: Tuesday,September 26, 2017, 05:48:51 PM »
Thanks JB and Bodzer, received two sets of bearing kits , complete with dust seal and grease.
And they fit😄. Usually I would get the numbers off the old installed bearings but they spun and ground off all ID.
   Completed all fiberglass repairs in wheel wells . Pictures to come.
« Reply #28 on: Tuesday,September 26, 2017, 08:06:09 PM »
Be careful of the aftermarket felt dust seals.  They are often too thick and don't allow the bearings to seat.  All the felt does is hold grease to prevent dust from getting in.  I usually just reuse the old felt (well greased).
Offline Bodzer
« Reply #29 on: Tuesday,September 26, 2017, 11:53:50 PM »
I got a bearing set from a reputable supplier and found one on the bearings was the wrong size. I was reading the Dave Bean catalogue and they have a Nylos seal set.  Perhaps they are still in a state of flux after Dave's recent passing. Good luck.
Pete
