Santa came early.
A/C leak check finally good after finding the NEW ,"go to" Schrader valve leak on the service fittings. there was a o-ring in place but since this is all aftermarket was to small for the fitting it had to go on. so that pushed forward alot of items that could go back together.
Then I managed to bleed the brakes with the one man bottle method. Working perfectly now but who really needs brakes , see pic.
JB and Turbo,
I checked the IPC and it shows the dowels are for an S2. That did not help me get them in.
NO WONDER IT TOOK LOTUS SO LONG TO BUILD A CAR.
Forget about going in from on top. the gearbox shape does not allow it.
From bottom, haven't tried your method yet Turbo. The machine screws I have in place may jus stay in...
With a few more screws and some trimming I'll have the firewall panels in place ,then a little liner just taped in place . then the rug.
