Author Topic: 1970 s2 0453R Reassembly  (Read 265654 times)
« Reply #1215 on: Thursday,November 19, 2020, 04:08:10 AM »
  JB,
   I heard of that , the reason for buying the package deal was to obtain the bell housing.
   I haven’t gone thru it yet to see what parts can be cross utilized. Lol the axle nuts alone were 1/5 the cost.
 The differential, axles, bearings, primary shaft , synchro’s...maybe?  Just guessing but wouldn’t the gears be able to be transferred for the proper rotation 4 forward, 1 reverse?
« Reply #1216 on: Thursday,November 19, 2020, 05:43:33 AM »
Everything except the ring and pinion should be useable... maybe the speedo-gear might be different, not sure.
Offline Broadside
    • Midland Race and Rally
« Reply #1217 on: Thursday,November 19, 2020, 12:00:43 PM »
  That’s a microfiber. It’s In a lot of new cars . It cleans up and vacuums very easily.
Thanks BDA
That does look really good, adds a real touch of class
« Reply #1218 on: Thursday,November 19, 2020, 12:18:06 PM »
 Thanks Broadside.
  The last piece of the puzzle . Need to final cut 5/8 larger and pin together so my wifey can sew it up.
« Reply #1219 on: Thursday,November 19, 2020, 06:20:02 PM »
  JB , I was reading and old thread on TC bell housing, grumblebuns had several pics of a 336/ 352 and a NG3 . I shot him a PM to see what his 336 suffix was . It was indeed a 336/66  with a TC housing on it . Talk about a shot in the dark.  The manual does not show or at least I haven’t seen a ref to it.
« Reply #1220 on: Thursday,November 19, 2020, 07:20:39 PM »
Good news!
« Reply #1221 on: Tuesday,November 24, 2020, 06:31:27 PM »
  Back on track. 😀
  My 821 is having a water test tonight on the liners.
So far no leaks. Tomorrow rods/ cam / timing gear . It fells so good to finally continue on the engine.
Pistons installed and move easily, now that all the rings are the correct size.
  Gearbox waiting patiently for final adjustments and comparison with another gearbox.
Happy Thanksgiving 🦃 Stay safe .
« Reply #1222 on: Tuesday,November 24, 2020, 08:20:29 PM »
Did you check your liner protrusion?
« Reply #1223 on: Wednesday,November 25, 2020, 04:32:52 AM »
   Check JB 👍.
    Debating weather to install the stock cam or the mild street due to the lower compression pistons. I don’t want a real slug. I believe the original pistons in that 821-30 were flat.
No leakage throughout the night.
  Lifters in head already also.
« Reply #1224 on: Wednesday,November 25, 2020, 06:53:43 AM »
62HP from a stocker should be plenty, D'man.  ;D
« Reply #1225 on: Wednesday,November 25, 2020, 07:23:19 AM »
  😂in my stories it will have 162 HP .   :FUNNY:
   I put in the mild cam all ready.
   The crossflow will make up the HP soon. Maybe even a zetec . I just want to make some noise and preferably not a bang.
« Reply #1226 on: Wednesday,November 25, 2020, 08:21:13 AM »
The mild street cam is a good choice.
« Reply #1227 on: Friday,November 27, 2020, 04:37:30 PM »
   Today my 79mm ring set came in for the crossflow 👍👍
  However the m12 x1.5 extended shaft tap does not fit in any block. All head bolts are m11 x 1.5
So I ordered another tap, and will let you know the outcome. So what I think happened is the PO installed a 7/16 20 instead of a 14.
« Reply #1228 on: Friday,November 27, 2020, 04:58:31 PM »
Great on the rings, bummer on the tap!
« Reply #1229 on: Friday,November 27, 2020, 05:35:59 PM »
 I ran across a cross section of the block with how the holes are designed in a Renault manual showing the top section being larger than the threaded section. No harm in waiting. Also the tensioner is hard to find . It has two different size pads and the larger seems only to be sold in the UK.
  I forgot to add that the 821 is turning freely with pistons, cam timing chain and tensioner installed.
Waiting on a front seal on timing cover. (Dec2) then the head is ready to go. Then gearbox and install.
 Tomorrow if I can get away before wife’s bday I’ll try to set up the gearbox. I’m sure that’s not going to happen but I can try.
