Author Topic: 1970 s2 0453R Reassembly  (Read 265876 times)
« Reply #285 on: Wednesday,August 01, 2018, 03:18:24 PM »
Went through the same rebuild as you Dakazman. Use plenty of lubricating grease during your reassembly (the red type that you can use with brake fluid).
« Reply #286 on: Wednesday,August 01, 2018, 05:09:02 PM »
 Thanks certified will do.
Started on the wiring harness and dash separation and rebuilding another heater unit .
Oh what fun finding all the p.o’s debacles, I cannot even call them repairs. I’m also building a
Harness layout board so to build harnesses, at least for an s2 federal.
« Reply #287 on: Thursday,August 02, 2018, 04:24:42 AM »
British Wiring sells a new harness for $580.  I have bought harnesses from them before (as well as visiting their shop). They are extremely well made and you will be hard pressed to match the quality and have all the right connectors.
« Reply #288 on: Thursday,August 02, 2018, 05:36:50 AM »
That will be a nice profit then. I counted 20 or so different colors I need to purchase. Normally I deal in one or two. I’m a little picky when it comes to wires.
« Reply #289 on: Thursday,August 02, 2018, 05:48:32 AM »
Ah yes, I had forgotten what you did for a living. Nice work. Your certainly well qualified to build your own harness! Looking forward to the updates.
« Reply #290 on: Thursday,August 02, 2018, 07:00:14 AM »
At one time some French cars used only white wire with identifying numbers printed at each end.  It worked but the numbers tended to fade and disappear over time which made electrical troubleshooting a more involved process on a 15 year old car.  I prefer systems where wire colours and stripes identify specific circuits.  On a British car, green is a fused ignition feed and green with a white stripe a turn signal feed.  Makes troubleshooting pretty easy.
« Reply #291 on: Thursday,August 02, 2018, 07:46:34 AM »
Lucas did us all a huge favor with their wiring color standard. As JB says, if you only preserve the green/white/brown/black part of it you will be miles ahead when troubleshooting.
I helped a friend with a Caterham with an electrical issue (you know he was scraping the bottom of the barrel when he called me!) and the PO had apparently felt it necessary to replace half the wires in the front of the car with red wires. It was a mess and much harder to find out what the problem was. We looked at a rear turn signal and the lamp was grounded with a green wire! Unfortunately, Caterham doesn't publish a wiring diagram. He really needs to rewire the entire car with the proper colored wires!
« Reply #292 on: Thursday,August 02, 2018, 08:04:09 AM »
 JB ,and BDA,
I will repair with correct color coding entire length.
 I agree, aircraft wiring is labeled every  6” with the wiring numbers,  impractical and to costly for
Cars. Color coding works well is this application.
But some people should not work on wiring! See pictures. My favorite was the red to white to blue repair, and the termination around the fuse.  I can send about 12 more what not to do photo ‘soft more amusement later.This harness is in the condition that I purchased the car 25 years ago for $1,000.
« Reply #293 on: Thursday,August 02, 2018, 08:20:41 AM »
+ 1,000,000%
My best how-not-to-repair-wiring story:
Some how a local Toyota dealer briefly was also a Rolls Royce dealer.  An 80s Shadow came in with a rhythmic clicking under the dash.  The "mechanic" found the problem removed the noisy item and bypassed it by joining the two wires together.  Well, it was a self-resetting circuit breaker -- i.e.:a very expensive fuse.  The car got 500 metres down the road and burst into flames, total loss.
I have lost count of how many times well-meaning owners have hooked up their jumper cables or batteries backwards.
« Reply #294 on: Thursday,August 02, 2018, 08:47:53 AM »
Well, at least we know how it ceased to be a Rolls Royce dealer
« Reply #295 on: Thursday,August 02, 2018, 09:59:37 AM »
JB, great story, I almost thought you were joking.
Bainford, Lol, like your humor.
« Reply #296 on: Thursday,August 02, 2018, 10:59:20 AM »
I would love to see a wire harness drawing (schedule of wiring?) that shows the actual gauge, length and routing of each wire the for the Fed TCS (or any Europa, for that matter). The schematic only gets you part way there. I sorted my wiring to the point that the essentials work and I can get my MA inspection sticker, but there are still dead-ended wires hanging everywhere.
My favorite car electrical story is the guy who used a .22 caliber bullet in his under dash fuse block. (Fits perfectly, btw.) This was reported in the Darwin Awards. He didn't kill himself, but he did take himself out of the gene pool, if you know what I mean, thus securing his place in the annals of Darwinism.
« Reply #297 on: Thursday,August 02, 2018, 11:49:35 AM »
Are these harnesses an exact replica of the OEM, including wire gauge? Presumably they are made to order; can 'one gauge larger' be specified?
I suppose these are questions I should ask British Wiring directly. When I eventually tackle the job of upgrading/improving my electrical system I think I would like to 'up-size' the wire gauge in some parts of the circuit for a little piece of mind. Perhaps it isn't necessary to do so, but I occasionally wonder if some parts of the system utilises marginal sized wiring for the task at hand, given some of the other weak points in the electrical system.
« Reply #298 on: Thursday,August 02, 2018, 12:34:58 PM »
British Wiring asks if you uprated your alternator, starter, etc so they can supply the proper gauge wire in the harness. They will custom make anything you like (for a price).
« Reply #299 on: Saturday,August 04, 2018, 06:25:19 AM »
 I’m so glad I decided to inspect the complete harness. Completed the tear down and marked all breakouts, flagged the concerns, and did some preliminary cost assessment and I’am finding out for what certified stated is well worth it .
   I am identifying some buried wire runs, cut and hanging  runs.
A big , Thank You for the color coded schematic of the federal S2.
