Author Topic: 1970 s2 0453R Reassembly  (Read 265658 times)
« Reply #60 on: Thursday,October 26, 2017, 06:53:54 PM »
Great progress, Dakazman!
It seems the usual material used for new firewalls is marine grade plywood covered in fiberglass. I'm not aware of anybody making a removable firewall but some people make a door for access to the front of the engine.
« Reply #61 on: Thursday,October 26, 2017, 10:07:32 PM »
I used 12mm ply, covered with fibreglass when replacing the soaked thick cardboard originally used.
Richard at Banks said he just glass fibre covers any bad original firewall. That is what I plan to do to 4129R this weekend.
As it is a "firewall", any removable panel should not compromise the passage of flame/smoke. Difficult to seal the perimeter of the removable bit.
Offline Bodzer
« Reply #62 on: Thursday,October 26, 2017, 11:55:10 PM »
Well done again!
How about Aerogel insulation sheets? My only concern is that Aerogel itself is hygroscopic but I think when it’s impregnated into sheets it isn’t much of a problem. Different types sheeting are available depending on the level of thermal performance required.
Offline Runningwild
« Reply #63 on: Friday,October 27, 2017, 04:49:10 AM »
I sandwiched the original firewall with .030 aluminum then aluminum honeycomb heat shield.
« Reply #64 on: Friday,October 27, 2017, 05:21:32 AM »
Now that is a FIREwall! :)
« Reply #65 on: Friday,October 27, 2017, 06:04:08 AM »
Not exactly “adding lightness”  :FUNNY:
« Reply #66 on: Friday,October 27, 2017, 06:14:26 AM »
That is a masterpiece 😀👍
That’s where I was leaning, aluminum and aircraft mechanics get along nicely. I only have a beef with getting to the fuel tank/ tanks. When I purchased the car the fuel tank was cut out of the bottom of the car. I am not going thru that repair again so that’s why I will split your design into 3 pieces.
Aluminum t- channel uprights and glass angle  around perimeter.
PS taking the day off . 😄 Became a Grandfather for the forth time last night
To a baby girl , Madison.
« Reply #67 on: Friday,October 27, 2017, 06:51:52 AM »
Congratulations on your granddaughter, dakazman!
Offline lotusfanatic
« Reply #68 on: Friday,October 27, 2017, 06:52:50 AM »
Dakazman,
Congratulations to you and your family!
« Reply #69 on: Friday,October 27, 2017, 07:25:02 AM »
Thank you
Baby and first time mommy healthy and doing fine😀.
Offline Runningwild
« Reply #70 on: Friday,October 27, 2017, 04:28:47 PM »
The alum and the heat shield only added around 5 pounds. Very light weight stuff
« Reply #71 on: Friday,October 27, 2017, 06:37:31 PM »
I like the look and layout of he heat shield material. Is the aluminum sheet on the engine side or under the heat shield? I’m assuming it’s on the engine side , hence the word sandwich.
The original “firewall” straw type sound board for material left much to be desired at least in my
Vechicle. Your addition is the closest to a true firewall.
« Reply #72 on: Saturday,October 28, 2017, 03:40:18 AM »
A fiberglass car will burn so quickly it doesn’t really matter what you add to the “firewall”. If you detect a fire in your car, get out! And fast.
How do I know? I’ve seen two Lotus Exige’s burn at the track. Even a complete fire suppression system in one didn’t stop it from burning.
All I’m adding to my “firewall” is a sheet of heat insulation on the engine side as I took out the old horse hair mat. It will be lighter.
Congrats on being a grandfather (again)!
« Reply #73 on: Saturday,October 28, 2017, 04:44:14 AM »
Thanks certified,
I held back on stating that. Its not that I believe it is a firewall but just a barrier for
Carbon monoxide, dirt , dust, water , fire , sound.
« Reply #74 on: Monday,October 30, 2017, 05:39:44 PM »
After reading a pfd  by Dave on firewall I have a new approach.
See pic 1 , view from engine compartment. Glass flanges going on.
   Secondly, final black going on see bonnet.  Bring up the level of engine compartment and front luggage compartment and spare tire area.
