Author Topic: 1970 s2 0453R Reassembly  (Read 264888 times)
Re: 1970 s2 0453R Reassembly
« Reply #975 on: Tuesday,April 07, 2020, 04:36:31 PM »
Still working on the doors and sub assemblies. Progress is slowly showing. Planning my assembly approach and gathering a few more pieces and some sealants .
 I will post the seal angle cutting how to if wanted.
   The love this car!
« Reply #976 on: Tuesday,April 07, 2020, 05:10:02 PM »
Great stuff, D'man! You did those corners A LOT better than I could!
« Reply #977 on: Tuesday,April 07, 2020, 05:42:56 PM »
  With the sealant afterward the seams will look seamless.  I just extended the seam line of the aluminum trim onto rubber strip. The second or third cut mated the two better but it’s on a angle and not flat to the seal.
   I drilled out all the rivet holes, placed all the trim in door channel. New fuzzies and window guide seals. I installed it and see why some have a problem installing the channel with window installed.
It needs to be installed but lower in the channel until the rivets are set , then pulled up.
 Attack plan ... locks and handle pulls installed. Window trim assembly with window installed in track.
Quarter window, power window motor assemblies.
  However I still need to adjust the sag in the doors, hang slightly low toward the lock assemblies but I need a good helper. My BA is also needed for bleeding my rear brakes, the front work great as far as leaks go. Driving and stopping power check later.
Stay safe everyone
« Reply #978 on: Tuesday,April 07, 2020, 06:28:01 PM »
I don't want to get between you and your BA, but there are all sorts of brake bleeders that allow you to bleed your brakes by yourself.  :)
« Reply #979 on: Wednesday,April 08, 2020, 04:55:40 AM »
Thanks BDA,
  I do have that tool... now to find it . I probably put it somewhere safe 🙃
« Reply #980 on: Wednesday,April 08, 2020, 09:36:03 AM »
I had forgotten about them but check out the thread on the speed bleeders in the Garage forum. I think starting with them is a good idea.
« Reply #981 on: Thursday,April 09, 2020, 06:41:08 AM »
  I found my self bleeding canister and tubing. Small miracle, it was with my dwell meter and vacuum gauges and carb flow meter. 😃
 Since I’m on lock down and my corvette motor parts are on delivery hold by GM , so is that job , 1 crankshaft main bearing pair. I found a deep gouge in it probably from that last machinist I told you all about.
  I tinkered a bit and carved out a mock defrost vent cover, since I couldn’t let some old Rtv go to waste,  I’ll make a pour a mold on it.🤪 I know I can buy them but I’m adding it to a collection of molds that I haven’t cast yet.
  Then I was back to my he seat trays , since they may hold thing up are now a priority to get sent out.
« Reply #982 on: Thursday,April 09, 2020, 02:23:20 PM »
   The first seat I welded in place after fabricating a new bottom section. Not to good but functional.
Second seat riveted In place much better. Probably saving time for the next repair due to flooding.😂
I just need to weld in the new nut to bolt it down.
Staying safe, 😀
« Reply #983 on: Thursday,April 09, 2020, 02:38:01 PM »
I don't know, they look good to me!  :beerchug:
« Reply #984 on: Thursday,April 09, 2020, 06:36:28 PM »
  Lol that’s the riveted one. The one I welded I chased burning thru the rust pockets even after cleaning the surfaces.  It was like welding a soda can, only worse. I ll post pictures tomorrow under what not to do.
   Trust me, I spent more time cleaning, blasting, prepping, painting etc ... I could have cut and riveted two new seat trays all ready. Now That I’m done and ready for upholstery.
Offline Sandyman
« Reply #985 on: Thursday,April 09, 2020, 07:02:27 PM »
Dave, riveted one looks good. I have heard welding rust is a losing game. As I am planning to redo my seats in the future, I am look forward to your upholstery adventure.
Sandy
« Reply #986 on: Friday,April 10, 2020, 05:57:32 AM »
  Thanks Sandy,
  Here is the tac and weld way done with oxy/acel .  So I didn’t do myself any favors this way if I trust out again.  That’s why I left one side just tacked in place.
« Reply #987 on: Friday,April 10, 2020, 03:28:14 PM »
   I was going to use this as the mold but decided to use it . I can always come back .
Instrument binacle  painted with gold, the entire console will be the same . A little JPS thrown in a little later.
« Reply #988 on: Friday,April 10, 2020, 05:10:48 PM »
Nice piece!
« Reply #989 on: Saturday,April 11, 2020, 09:39:41 AM »
Thanks BDA,
  I’ll try to have a pic up today with the instruments installed and in the dash.
  On another entirely different subject but one that was discussed on groups was the bonnet bolts.
So I gathered up some scraps and designed this simple pull cable to release both sides of the bonnet at a the same time and one person install.
 The assembly still need a rubber hose tube to protect the cable and a little easier to pull. Rivets for the L channels and glassing in the u channel to underside of bonnet on both sides.
One other piece is a return spring, I only had one laying around. Then adding lightness.
Feel free to comment!🤣
