Author Topic: 1970 s2 0453R Reassembly  (Read 265614 times)
Re: 1970 s2 0453R Reassembly
« Reply #30 on: Wednesday,August 02, 2017, 05:36:25 PM »
Thanks , here's some more pics
« Reply #31 on: Wednesday,August 02, 2017, 05:49:03 PM »
I see it is an 843  but how do we determine the - #...
13/15/17 gordini is labeled , gordini.?
« Reply #32 on: Wednesday,August 02, 2017, 08:50:09 PM »
Only early 807 engines had the high compression, large valves and large ports that people associate with a "Gordini" engine -- BTW, Gordini actually had nothing to do with the 8-- series engines.  An 843 can be brought up to "Gordini" spec by fitting larger valves, porting the head, fitting h-c pistons, etc.
« Reply #33 on: Thursday,August 03, 2017, 05:43:23 AM »
My 821-30 engines also coming along and getting it ready for machinist, but I need to order gasket for liners , paper type. The shop will set the liners and send out cranks and cams. yes 2 each of the 821's.
Heads now completely torn down and accessing conditions. The original engine block will be reinstalled with parts from both. Only after rebuild will I consider undertaking the 843 , but will start looking for the parts.
« Reply #34 on: Thursday,August 03, 2017, 12:37:12 PM »
Just finished the headlight assemblies and decorated garage. Lol
« Reply #35 on: Thursday,August 03, 2017, 02:45:57 PM »
Other items in work...paint on the corvette and el Camino.
« Reply #36 on: Thursday,August 03, 2017, 04:47:02 PM »
That will keep you off the streets!
« Reply #37 on: Saturday,August 05, 2017, 09:43:42 AM »
Just received an original air cleaner and was wondering if anyone could tell me what an original cutout looks like. Or PDF an drawing of a tracing😁
Thanks in advance
« Reply #38 on: Friday,August 18, 2017, 04:48:34 AM »
 Finished the lower plate in the air cleaner and readied new plate for welding back in.
On a separate note purchased a rear luggage compartment found on eBay after 25 years
It needed a few repairs but coming along. Other items completed were radiator fan assembly and demister fan
« Reply #39 on: Monday,October 02, 2017, 06:18:46 PM »
As stated earlier I finally found a tray for aft compartment, here some pics of
The progress of filling all the holes and cracks. Primed today and I will post those soon.
Wheel wells and tunnel pics and progress. Wheel well undercoating was terrible to remove.
Newer Honda wheel well material will be attached to keep road noise down.
« Reply #40 on: Monday,October 02, 2017, 06:24:48 PM »
Body in prime.
« Reply #41 on: Monday,October 02, 2017, 06:59:46 PM »
Also front turn indicators need to be redone because they were glassed with fabric and they are
Lopsided. So I made the inserts and will install correctly this week.
« Reply #42 on: Monday,October 02, 2017, 07:52:14 PM »
Looks like a lot of work ahead of you! Thanks for the pictures! Keep them coming!
« Reply #43 on: Monday,October 02, 2017, 08:20:08 PM »
Wow! You've really been on a roll. Looking great!
« Reply #44 on: Thursday,October 05, 2017, 04:08:52 PM »
 New turn signal holders. Rought install.
