Re: 1970 s2 0453R Reassembly
« Reply #1995 on: Friday,September 22, 2023, 01:01:29 PM »
   Thanks BDA ,correct, not much coming out of tailpipe, I just needed some piece of mind, some yes, but near the center exhaust header wrap area, was most of it . I don't know what type finish is on the RD headers, Paint or powder coat I thought they were Powder.  Then the muffler wrap might have sucked up some oil.
 I moved onto cutting and forming the rubber seal for windscreen, been at one edge for over an hour now .
« Reply #1996 on: Friday,September 22, 2023, 04:41:57 PM »
This trim is very tricky to cut inside and out and line up glass seat and final lock trim.  I’m slowly managing to make my way around.  I had the side pieces clamped to some L channel to keep straight for a month. Using some paint stick clippings as a wedge shows the alignment when glass in place .
The lower right corner still needs some trimming still yet
Adding pr1425b will secure and fill the bottom and edge cuts . Great stuff and sticks to everything.
« Reply #1997 on: Saturday,September 23, 2023, 03:00:11 PM »
  Spent the day cutting my lawn and do oing my outdoor chores that I’ve been neglecting.🥱
So afterwards I just about finished all the rubber trim  . Wow what a pain.  I just need to trim out the top right just a tad more.
  Window tomorrow 🤞
   Talked to the carb seller and I asked several times for specifications and the answer I got was hilarious, see pic😂
« Reply #1998 on: Saturday,September 23, 2023, 03:11:29 PM »
That is part of the reason I am trying to avoid parts made there.....
« Reply #1999 on: Saturday,September 23, 2023, 03:28:25 PM »
Said in my best Chinese voice:
Why you hab wubber gasket, D'man san?
Thought you had Type 65?
« Reply #2000 on: Saturday,September 23, 2023, 05:56:28 PM »
  GavinT
   Lol,
          That’s what I had on the car.  I called RD and order one for an S2 type 65, with SN .
  I saved the rubber for over 30 years.
« Reply #2001 on: Sunday,September 24, 2023, 03:09:03 PM »
  GavinT,
   So close ! Started at 3:30 at 500 pm  I quit for the day
 I have one seal left to do  as I tried something different to get it to fit. After some pain killers I’ll try again tomorrow on to inner seal top seal.
« Reply #2002 on: Sunday,September 24, 2023, 05:42:04 PM »
Well, there ya go.
I thought all 65's would have come with bonded in glass because the associated screen recess was dictated by the upper body mould.
But yes, fitting the rubber is a pain partly because the corners need to be cut to accommodate the multiple plains of the joints.
You'll win in the end.
« Reply #2003 on: Sunday,September 24, 2023, 06:18:57 PM »
  You had me worried at first, still it’s going slower than the rear window and I haven’t put in the chrome plastic lock strips yet either . More fun tomorrow… maybe if I’m not to sore.
« Reply #2004 on: Monday,September 25, 2023, 09:36:29 AM »
  I just couldn’t sleep thinking about all the smoke during the last run so I rechecked the head torque , checked the water level, filled my lawnmower gas tank and cranked her up .
  Much better.
 https://youtu.be/r7VFhpzAcVg?feature=shared
 Now to bleed the coolant lines .  Get that window in , that’s why it’s outside, loosen up these seals.
 I also can reinstall one firewall panel. Waiting on oil pressure line and gauge.
A slight wobble is showing on the cam pulley, any ideas how to adjust it , do you loosen it up then run and retighten?
« Reply #2005 on: Monday,September 25, 2023, 10:22:50 AM »
Yep, it's all burned off now...
« Reply #2006 on: Monday,September 25, 2023, 12:20:02 PM »
Just noticed the flares ...what size tires are running?
« Reply #2007 on: Monday,September 25, 2023, 12:22:37 PM »
  It was my first engine completely assembled by me , parts from all over the world.
Thanks to many members here I “ Got Her Done” .  Usually It’s “Get Her Done” .  I still have a lot to do on it and getting used to the sound of the solid lifters. Not exactly the sound of roller lifters.
« Reply #2008 on: Monday,September 25, 2023, 01:38:04 PM »
  I have 185 60 13 up front on 6” panasports and 205 60 13 in the rear on 7 in panasports
« Reply #2009 on: Monday,September 25, 2023, 02:26:28 PM »
First engine... Well done!!!   :beerchug:  :BEER3:
