The 35 year old Sperry has been acting up after I lent it out. Maybe I should also change the 9v battery. The harbor freight feebee has been working better. I’ll dig out my Simpsons too .What is really nice is working with test light’s which are frowned upon for commercial aircraft. You are allowed to use test boxes that have calibrated bulbs.
Your suggestion to use test lights. 👍👍Using two, one one each side of car is helpful.
The new coil, distributor caps , rotors and a slew of new rubber connectors . Also a variety of bullet connectors.
The new water pump is due tomorrow.
While sitting and looking at the wiring diagram I see that the ignition switch should be grounded.
Mine is just laying there on the carpet.🤔🤔 another question I have is what is the internal connections through the start relay w2 connection.
I’ll also be double checking the ignition switch to harness connections , heavy spade connections with rubber boots that are not shown on the wiring print . See pic. Maybe the spades are just laying next to each other.
Tomorrow is another day.
