Re: 1970 s2 0453R Reassembly
« Reply #1725 on: Saturday,August 13, 2022, 04:22:44 PM »
They work but you need the matching gauge.  It only works when you turn the key on before starting.  I would just plug it off
« Reply #1726 on: Saturday,August 13, 2022, 04:59:32 PM »
  Thanks JB, your input is valued.
BTW do you have the dimensions of the woodruff key p/n 046 e 6075? Renault camshaft.
Thanks in advance.
« Reply #1727 on: Saturday,August 13, 2022, 05:05:17 PM »
 Finished up these cover plates but the distributor shaft cover I’ll shave off a few more grams. See pic.
I found my oil pan drain plug but I just ordered 2 m16x1.5 drain plugs from Napa along with the copper washer.
« Reply #1728 on: Saturday,August 13, 2022, 06:19:21 PM »
No.  Just measure the keyways in the gear and the cam.  You can then buy key stock and make your own.
« Reply #1729 on: Sunday,August 14, 2022, 04:27:10 PM »
  After finishing my hurricane prep for the past two weekends I had time to run out a buy some keys that were in a kit . None of the doorman set fit correctly, just to loose for me.
  I have plenty of bar stock for key ways and made my own .  Tomorrow I should be able to finish the timing gear and then install head . 🙏
« Reply #1730 on: Tuesday,August 16, 2022, 04:04:16 PM »
  All though it not yet going in , I completed what I refer to as a milestone. 😄
   Building a cross flow was time consuming but I loved every minute of it. More details to follow but here are some pics. Not a mock-up this time.
  I need to buy an electric fuel pump and some roll pins for the rocker assembly.
« Reply #1731 on: Tuesday,August 16, 2022, 04:06:32 PM »
That's a nice looking engine DMan  8)
« Reply #1732 on: Tuesday,August 16, 2022, 06:07:58 PM »
Thanks Turbo, your mods are also looking great.
  It’s a work in progress, adding the crankshaft pulley for an A/C system, so it’s my current 821 on a crossflow. Getting the fit is another story, twin Weber 45’s still need to be purchased.
« Reply #1733 on: Wednesday,August 17, 2022, 10:01:39 AM »
A thing of beauty  :trophy:
« Reply #1734 on: Wednesday,August 17, 2022, 04:58:01 PM »
  Thanks Silver.
  Here is a sneak peak of the rest of it , a shopping and to-do list for me. Mainly Bolts, Webers and linkage, electric fuel pump top of my list . Transfering my 59$ New water pump pulley mount on the list of to do’s but having trouble talking with a vendor for tooling.
  Now I can get back to the car. Maybe!!!! Read my off topic post 😂
Sneak pics:
« Reply #1735 on: Wednesday,August 17, 2022, 05:51:14 PM »
 8)
« Reply #1736 on: Friday,August 19, 2022, 06:45:38 AM »
  Thanks Turbo, 👍
 Getting back to water pumps , I decided it’s better to be more adaptable by just drilling hole on the Renault pulley to fit the newer pumps that can be purchased much cheaper and fit newer model pulley’s.  Made a template and drilled some pilot holes to get centers just right but offset to the current holes .
« Reply #1737 on: Friday,August 19, 2022, 06:39:09 PM »
  Finished final torquing and initial valve adjustment, everything turning freely.😅
   Compiled a list of parts necessary to complete. Sticker shock set in when trying to find m8 1.00 nuts, m7 x 1.00 shoulder bolts . Yikes if you can get them in various lengths.  Now to get back to hands on the lotus. I’ll save the rest of the polishing to my spare time.
« Reply #1738 on: Saturday,August 20, 2022, 04:30:23 AM »
That looks awesome!
« Reply #1739 on: Sunday,August 21, 2022, 09:11:10 AM »
  I couldn’t resist hanging a few more parts so I can get a better idea of space available for the ac compressor location.
  Hung the header and played around with a dipstick location. Then I went back into my storage and found a single carb setup , which would you choose?  I have been scouring the internet  for webers  dcoe’s but now I’ll broaden my searches.
