Author Topic: 1970 s2 0453R Reassembly  (Read 265923 times)
Re: 1970 s2 0453R Reassembly
« Reply #1620 on: Monday,February 21, 2022, 03:02:33 PM »
   Clutch pedal cable completed, brake pedal next. Then a trip to the salvage yard to pick up ac lines . My last trip there was eye opening with the amount of lines and hoses available.  They are on the other side of the car and until I gather some lines up , I cannot install carpet.
« Reply #1621 on: Thursday,February 24, 2022, 03:40:00 PM »
 It’s time to light this off.
  Found enough time to take down my wiring build board and lay it down to wire the dash in. However I felt better to lace up the harness so that it lays out better. I’ll add additional wires in the car for all the upgrades.  Dash will get wired tomorrow. 😃
  The routing of the harness will also be slightly different as to I will hide a many as possible from sight.
« Reply #1622 on: Thursday,February 24, 2022, 04:15:26 PM »
 :FUNNY:   :FUNNY:   :FUNNY:
« Reply #1623 on: Thursday,February 24, 2022, 04:38:22 PM »
  Ooops, that’s our world leaders looking for answers. Not me hiding wires😂
« Last Edit: Thursday,February 24, 2022, 04:40:13 PM by dakazman »
« Reply #1624 on: Thursday,February 24, 2022, 05:13:23 PM »
Very true!
« Reply #1625 on: Saturday,February 26, 2022, 03:32:26 PM »
After finishing up several honey dos  I managed to  throw the kitchen sink at the harness. Made some progress even when disturbed every minute.
« Reply #1626 on: Tuesday,March 01, 2022, 12:39:28 PM »
  The harness is now off my build board and ready to install. Once in , I’ll route in, “mostly “ the same factory routes. Hiding as much as I can, and adding a new runs on all grounds, headlight and taillights.
I know it sounds strange not to run when out but it will reduce waste. I still have a bit more untangling to do 😜.
« Reply #1627 on: Wednesday,March 02, 2022, 08:32:17 AM »
Dakazman, since you have it loose there, could you take a picture of the side view of the trip odometer bracket? A PO had removed the cable and bracket. I found a replacement cable from a fellow lister, but wonder what the bracket looked like. Also, where was it attached to the back of the dash? The Parts List only gives a general idea.
« Reply #1628 on: Wednesday,March 02, 2022, 02:44:38 PM »
Kendo,
hope this helps. Don’t look at the brake fail light switch next to it . That is now my wash button.
« Reply #1629 on: Wednesday,March 02, 2022, 03:46:02 PM »
So that’s like a 135 degree angle near the center console. I expect to add a couple of switches to the bracket, too. And of course, black  8)
Many thanks. That helps.
« Reply #1630 on: Wednesday,March 02, 2022, 05:32:09 PM »
I may have a picture of the brackets itself when I took it off the old dash. I try to post tomorrow.
« Reply #1631 on: Monday,March 07, 2022, 10:16:09 AM »
   Off to a good start today with the dash inserted in car . I made a temporary pvc pipe bracket to suspend the dash in vehicle with safety wire . I can easily maneuver it around to route the harness and extend wire runs .
« Reply #1632 on: Monday,March 07, 2022, 11:06:20 AM »
That's great stuff, D'man!! It's beginning to look like car on the inside!
« Reply #1633 on: Monday,March 07, 2022, 01:21:28 PM »
Nice!
What's the PVC rack for?
« Reply #1634 on: Monday,March 07, 2022, 02:05:15 PM »
  It just a nice swing attachment for the dash . Whilst I add in some other system wires and decide where to put the new fuse box/ boxes. Those wires will be rerun thru the harness in their full run. Luckily those wires are easy to purchase at a decent price.
