Author Topic: 3276R - 1973 Special  (Read 2408 times)
Offline Daysineuropa
« on: Sunday,May 21, 2017, 01:22:25 PM »
Making slow but steady progress.  Front hubs rebuilt and new pads and rotors fitted.
Special master cylinder removal was a challenge, now on to rebuilding it.
The reservoir attachment method is as cruel and unusual as the location of master cylinder relative to steering rack.
I have read posts mentioning drilling a hole to destroy circlip. Surely Girling must have considered the need to service the unit.
Any inspiration for safely removing the reservoir?  Feeling a Wilwood remote reservoir, tandem replacement coming on......
1973 TCS 3276R
1971 S2 1287R (sold)
Sunbeam and Hillman Imps and Stiletto.
Re: 3276R - 1973 Special
« Reply #1 on: Sunday,May 21, 2017, 03:30:54 PM »
I think I saw there was some special tool to take it off. If you are going to rebuild yours, you might want to consult a shop that specializes in old British cars before you do anything drastic. You might consider sending it to White Post Restorations (whitepost.com). They will certainly take it apart properly and sleeve it for longer life. They have pretty quick turn around too.
« Reply #2 on: Wednesday,May 24, 2017, 11:14:29 PM »
Apparently dental style forceps and another Europa owner were all that was needed.
Visited Dr Dean today and had a successful extraction.  Uniform upward pressure did the job with minimal damage to the shoulder on the reservoir.
Onto the rebuild.......
1973 TCS 3276R
« Reply #3 on: Thursday,May 25, 2017, 05:31:14 AM »
And some people don't like to go to the dentist!
« Reply #4 on: Saturday,December 21, 2019, 04:30:28 PM »
So after much fighting and deliberating, off came the body.
Rear hubs and gearbox have been rebuilt.  I am going to put simple single circuit brake system in, no servos.
How far to go?  Suspension set-up changes?
1973 TCS 3276R
« Reply #5 on: Saturday,December 21, 2019, 04:37:14 PM »
You know, they work very well with the stock set-up.  It's a TC so you already have the larger u-joints in the half-shafts.  Careful, by-the-book assembly of the rear uprights and you should be good.
