Author Topic: Radiator fan relay wiring  (Read 2172 times)
Offline Gmg31
« on: Friday,May 12, 2017, 02:57:14 AM »
Unfortunately the wiring diagram is far from clear for this task and I think relay labels have changed.  Does any one know how to wire up the relay on the S2
We have
Black + Red/black
Black
Purple
Green +green
Modern relay is labelled
30
85
86
87
Re: Radiator fan relay wiring
« Reply #1 on: Friday,May 12, 2017, 07:09:22 AM »
http://www.gtsparkplugs.com/images/mini-automotive-relay-wiring-840x.jpg
Purple (fused battery +) goes to the 30 terminal
Double Green (fused ignition) goes to 85
Black/Red-Black (rad fan switch and dash fan control) goes to 86
Black probably to 87 (should be the rad fan feed but double check using a continuity meter)
Offline Gmg31
« Reply #2 on: Friday,May 12, 2017, 07:58:02 AM »
You're a star JB thank you.
Offline EuropatcSPECIAL
« Reply #3 on: Friday,May 12, 2017, 06:38:09 PM »
Im always amazed how there is always someone with the desired information, good call JB   :trophy:
Offline Gmg31
« Reply #4 on: Friday,May 19, 2017, 07:35:06 AM »
Anyone know Why is the red/wire connected to the heater fan switch? What does it do?
« Reply #5 on: Friday,May 19, 2017, 12:38:39 PM »
The heater fan switch has three positions:
- off
- heater fan on
- heater fan and rad fan on
Offline Gmg31
« Reply #6 on: Sunday,May 21, 2017, 08:49:30 AM »
Oh that's interesting. I've replaced my switches so I need to consider if that wire is important.  Does the red/black wire trigger the radiator fan by going to earth? If so I gues I could just add another switch. Thanks for your help
« Reply #7 on: Sunday,May 21, 2017, 03:34:10 PM »
Yes, it earths the relay to turn on the rad fan.  The original heater fan is a single speed.  Fused ignition power to the heater fan and it earths through the switch.
Offline Gmg31
« Reply #8 on: Wednesday,May 24, 2017, 02:33:43 PM »
Great thanks.
Offline Gmg31
« Reply #9 on: Wednesday,May 31, 2017, 05:43:05 AM »
wired it all up last night and it worked first time.    Creeping ever closer to the finish line.
Thanks for your help.
