Author Topic: Straight coolant tubes  (Read 907 times)
Offline Runningwild
« on: Wednesday,May 03, 2017, 01:41:22 PM »
Coolant tubes are installed. Straight tubes are much easier. New front driver side holes were a bitch to line up and drill (inside chassis ). Plenty of room now for the cable shift brackets. I'll use silicone bends to finish plumbing the system.
Re: Straight coolant tubes
« Reply #1 on: Wednesday,May 03, 2017, 02:44:50 PM »
I don't have any direct experience with silicone hoses, but I understand they need to be tightened much tighter than rubber hoses. Just something to keep in mind early so it doesn't bite you later!
Offline Runningwild
« Reply #2 on: Wednesday,May 03, 2017, 07:00:49 PM »
We use them on the race car with turbo clamps. Work great. Thanks BDA
« Reply #3 on: Wednesday,May 03, 2017, 09:28:59 PM »
What's a turbo clamp look like ? (serious question, I've never had to use/buy one before)
« Reply #4 on: Thursday,May 04, 2017, 04:16:06 AM »
Yes i can vouch for silicone hoses needed a higher clamp pressure especially on stainless steel tubing. I used  Mikalor clamps. and make sure the silicone hoses don't have release agent on them.
