Author Topic: Steering rack rebuild question  (Read 533 times)
Offline Runningwild
« on: Friday,April 28, 2017, 05:04:03 PM »
Just got the rack finished. Had to soak for a week to loosen up the 40 year old grease.  There is a hole under the red marker. Is that a vent?  Should it be covered or left alone?  Seems like water could get in there.
Re: Steering rack rebuild question
« Reply #1 on: Friday,April 28, 2017, 05:21:37 PM »
Isn't it covered by the mount?
« Reply #2 on: Friday,April 28, 2017, 05:37:14 PM »
I believe John is correct. The hole in the rack on my TCS was covered up by the mount, too.
Offline Runningwild
« Reply #3 on: Friday,April 28, 2017, 06:41:04 PM »
Ok. Thanks -didn't mount it yet. What was the reason for the hole?
« Reply #4 on: Friday,April 28, 2017, 10:39:33 PM »
Dunno, so you could add oil easily?
Offline Jerryh
« Reply #5 on: Sunday,April 30, 2017, 01:18:06 AM »
I think it's a locating hole for a bush that's in the tube of the rack.
Offline RoddyMac
« Reply #6 on: Sunday,April 30, 2017, 08:42:15 PM »
There should be a nylon bush/plug in the hole, see item 66 in the following link:
http://www.moss-europe.co.uk/shop-by-model/triumph/spitfire/steering-suspension/steering/steering-rack-lower-column.html
